Old 01-31-2004, 11:39 PM
micky69396 micky69396 is offline
Default Race 427 short block BBC
427 BBC short block+.060 439 CI. 4 Bolt main, 1/2 filled, still can run water, steel crank, Wiesco pistons 12.5 comp (open chamber), Brooks alum rods, crane roller cam and lifters, Double roller chain, Childs and albert bearings, Total seal rings, ARP head studs, Moroso blueprint pump, only 9 passes since freshened. No Pan, timing cover, or balancer. Asking 3K obo.
Old 02-02-2004, 07:32 PM
SMGCO SMGCO is offline
Default Re: Race 427 short block BBC
What casting number is the block ? Has it been sonic tested ? What cam is in it ? Thanks, Steve Goddard
Old 02-02-2004, 11:24 PM
Dont know the number, it was a new GM 4 bolt block, not a bowtie. Its never been hurt and it ready to go. I will have to go back thru my papers but its around a .720 lift roller in it. I used it with injection and alky. I have attached photo.
