Old 01-07-2004, 02:55 AM
resto4u resto4u is offline
Default Engine sleeves?, rebuild?
Has anyone ever re-sleeved an engine, all cylinders? Did you have any problems? Or anyone sleeve any number of cylinders? Just looking for some good feedback, pro's and con's. Thanks,Roger
Old 01-07-2004, 03:11 AM
Pantera Pantera is offline
Default Re: Engine sleeves?, rebuild?
One of my SCCA B/P small blocks had to be sleived and it runs dam fast and gives no problems. Kinda expensive but if you need that block for the S/N then it will be worth it. Just be sure that you have it done by someone with a fixture that bores it using the mains as a guide to get them located correctly.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 01-07-2004, 03:47 AM
68ys8030 68ys8030 is offline
sleeves are very strong when installed properly. I've sleeved entire blocks for people many times. i get 100.00
per hole for the sleeve and installation. if you have that matching block you can save it ! really you should tru the decks when done but if you are lucky it wont take much to clean them up and your original number stamps might still be visible! my 2 cents worth...
steve
63 split window fuelie
69 z28
financing my 2 sons cars.... 67 fastback mustang and 69 Camaro.
Old 01-07-2004, 05:29 PM
olredalert olredalert is online now
------Sleeving is perfectly acceptable if done correctly as already stated. As well,I feel that the sleeving should be divulged at the time of sale. It is an important aspect that needs to be known by any purchaser........Bill S
