Old 12-17-2003, 04:17 PM
bilede bilede is offline
Default Yenko deuce rear sway bar.
Can anyone provide me with the width from side to side of the rear swaybar for a deuce along with how long are the vertical bars? I picked up a complete setup and I think the bar is correct but not sure about the verticals.. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Old 12-17-2003, 04:55 PM
Default Re: Yenko deuce rear sway bar.
I can measure mine tonight.
The 'hangers' should bolt below the bar, not in front of it, when properly mounted to the special lower leaf spring brackets.
Old 12-18-2003, 05:42 PM
thanks Marlin, that would be great if you would.. [img]/ubbthreads/images/graemlins/worship.gif[/img]
Old 12-23-2003, 03:11 AM
Help, still no answer, does anyone have this info please???
Old 12-23-2003, 09:01 PM
mnyenko mnyenko is offline
Bill,
The sway bar set up you saw in my garage measures 38 1/4" wide on bar.The verticals measure 11 1/2" center to center on bushings.Over all 13" on verticals.This unit is from a 74 nova with f41.The verticals have the lower bolt connection facing the wrong way for a 70.But should be the same dimensions.Earl
Old 12-24-2003, 03:32 AM
Bill, I will try to remember to measure mine. You most likley will have to remind me though. Send me a pm if I forget. Schonye
Old 12-24-2003, 10:48 PM
JRSully JRSully is offline
Measured the rear sway bar off my 70 L78 F41 car, 38 3/8" tip to tip, with a yellow paint mark on one end, hope this helps.SULLY
71 Porsche 911 Targa
Old 12-30-2003, 03:32 PM
Thanks guys for the info!!! thats exactly what I needed.
Old 01-01-2004, 03:42 AM
Bill, sorry I took so long. My droparms measure 14.5 in from where they attach up top, to the bottom. It measures 25in between the drops on the bar, and 33in to the inside where it goes throught the rubber mount. Mine has never been off. Schonye
Old 01-02-2004, 06:02 PM
The vertical bars have different c/l measurements, the Nova version is a little longer than the Camaro/later Nova version, but both will work.
