Old 12-13-2003, 11:49 PM
William William is offline
Default SW tach wiring
I'm curious as to how the SW "tachometer wiring kit" was configured-these are the dotted lines on the SW schematic. Were the wires loose or was it the same 4 conductor phone cable?
How did Yenko...
-terminate the black ground wire?
-connect the red wire? Was it spliced into the resistor wire or inside the car at the ignition switch?
-connect the white (panel lights) wire? Was it terminated at the fuse box?
Thanks guys
Old 12-17-2003, 02:48 PM
JoeC JoeC is offline
Default Re: SW tach wiring
I would think that Yenko mechanics would follow the original SW instructions but some may have been installed different then others. I have an original SW tach wire kit with metal clips that fit into the fuse box. The clips look like fuse holders with a tab to connect a wire clip. They install under the original fuse. These would make for a quick installation for some of the wires but I am not sure if Yenko used them because I am not sure if these came with the Tach or if it was an extra cost kit. Maybe someone with an original unrestored car can answer this?
Old 12-17-2003, 08:25 PM
BACKN 68's Avatar
BACKN 68 BACKN 68 is offline
William,
The SW "tachometer wiring kit" consists of four seperate wires. The RED,WHITE & BLACK are each 24 1/2" in length. While the YELLOW wire is 73" in length. These measurements are from an NOS 970 SW tach and sending unit. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Kent
Old 12-18-2003, 01:49 AM
Thanks for the info. Sounds like there was room for interpretation on the part of the installer.
