Old 12-11-2003, 04:57 PM
redbaron redbaron is offline
Default Holley Carb Question
On the 69 L78 or L89 camaros where are the fuel filters located.
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
69 Ls7 T56 Camaro Project
Old 12-11-2003, 07:09 PM
COPO COPO is offline
Default Re: Holley Carb Question
A bronze filter was installed in the carb inlets where the fuel line attaches. They were notorious for causing stumbling and rough running problems over time and many people discarded them and installed a high flow inline filter.
Old 12-11-2003, 07:27 PM
I was sure that was the case. Where is the best place to hid an inline filter to keep the solid fuel lines from the pump to the carb intact? Thank You
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 12-11-2003, 07:57 PM
NCGuy68 NCGuy68 is offline
In the area where the fuel line exits the tank would be good. Obviously, you'll have to modifiy the fuel line which may not be a good idea on a original car if thats what you have.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 12-11-2003, 08:17 PM
This is an original car, but hiding the filter is not that big of deal to me. I guess I could use a Q-Jet type filter and fab a new solid line from the filter to carb block,then plug the return line out of the filter. Any ideas appreciated.
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 12-11-2003, 08:39 PM
Eddie M. Eddie M. is offline
at the back where the rubber line from the tank hooks to the fuel line is where i have mine you can see it behind the rear tire but you have to get down to see it
69 ZL1 Camaro
70 Nova
Old 12-11-2003, 11:33 PM
DjD DjD is offline
The solid line from the tank is attached to the fuel pump with a short section of hose. Get an AC stamped filter from one of the repro houses and stick it inline there... You don't have to get under the car and the AC stamp lends itself to period correct. I don't think many will fault you for added fuel filtering even on a stock restoration...
[img]/ubbthreads/images/graemlins/[/img]
Dennis
White Wonder
Old 12-12-2003, 12:05 AM
I had thought about using that spot, just did not think of using an AC stamped filter. Good idea!
Thank You Dennis
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 12-12-2003, 02:04 AM
Perhaps I missed something here...
The original question was 'where to hide a inline fuel filter' on a big block 69 Camaro.
Installing any inline filter visable in the engine bay don't cut the mustard on a original car AC stamped or otherwise.
There are other alternatives.
Craig S.
John Force.
Old 12-12-2003, 02:23 AM
RPZ28 RPZ28 is offline
There are paper filters available that replace the bronze ones. They work 100% better and the best thing no modifications necessary.
Ron
