Old 12-08-2003, 06:08 PM
Ironhorse Ironhorse is offline
Default Alum. head question.
I have a 68 Camaro 396 that I'm working on. the motor is not the orignal motor. ( it's from a 69 chevelle ). What my question is. Can you fit aluminum heads and tri carb. intake from a 427 vette engine onto this engine?. Kim
68 Camaro 396 conv.
66 Impala SS427 conv.
66 Impala SS327 ht.
Old 12-08-2003, 06:20 PM
COPO COPO is offline
Default Re: Alum. head question.
It's an easy bolt-on. Tuning the carbs will be the fun part. [img]/ubbthreads/images/graemlins/[/img]
Old 12-09-2003, 01:09 AM
NCGuy68 NCGuy68 is offline
AMEN!
However...if the Tri-Carb setup is factory original, you might want to reconsider using it on a "project" car. That 427/435 combo is very desirable and highly sought after by the 'Vette guys as well as many others.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 12-09-2003, 01:15 AM
GMH454 GMH454 is offline
What sort of alloy heads are you talking about. The 074 and later ZL-1 style, plus other racing style heads are probably not suited to a tripower unless you were contemplating running it with a manual mechanical likage instead of vacuum.
The earlier style heads have the "normal exhaust " and would be better. ....actually a small port set up with the edelbrock small port style heads might be a sweet street combo, but not have the visual you are after.
If you get it wrong and it drives like a pig, the style of set up your talking about is not cheap experience.
Old 12-09-2003, 01:36 AM
Well. To answer your question. The Alum. parts are off of a blowen-up 427. I was told that the engine came out of a L-89 69 vette that was destroyed. The bottom-half was what was destroyed. so I don't even know if the heads are any good. thay don't look damaged. Kim
Old 12-10-2003, 12:43 AM
If they are from a L-89 they would be perfect for a good street engine.
Check that they have the winters snowflake, and the shape of the exhaust ports, If square they are right, if round, they are second gen, ZL-1 style heads, and benefit from high RPM big cam. Think twice before using them on a street engine.
I changed to them from good street heads, and was disappointed. Lost my bottom end torque.... round 4000 it gets to be fun, and it is a restored drag/street car, so that is okay, its just that the trip to the track will not be a lot of fun.
Good luck.
Old 12-10-2003, 09:28 AM
Stitch Stitch is offline
Don't you mean the intake ports ?
Old 12-10-2003, 07:16 PM
TimG TimG is offline
Intake ports are all square on aluminum heads, exhaust ports differ if I remember correctly.
Old 12-10-2003, 09:20 PM
No , low and mid perf BB heads had oval intake ports and bigger chambers , all high perf BB heads had rectangle ports and bigger valves . But by fitting the 2.19 and 1.88 valves into oval port heads and a little chamber and port work you'll end up with some low buck stump pullers [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Old 12-10-2003, 09:44 PM
Stitch, we are talking of GM winters alloy heads here.
They all have the same intakes, it is the exhaust that differs.
There never were any low or mid perform. Alloy heads.
[img]/ubbthreads/images/graemlins/scholar.gif[/img]
