Old 10-31-2003, 02:59 PM
jbclassics jbclassics is offline
Default Big Block Frame Mounts
I purchased new frame mounts for my 69 Nova restoration from Chevy 2 only. When you lay the mounts on a bench they are different heights.....the drivers side is higher than the passenger side. The passenger side also has a slot verses a hole for the motor mount bolts.
My question should these mounts be different heights ???
Any help is appreciated. [img]/ubbthreads/images/graemlins/confused.gif[/img]
Jeff
1972 Chevelle "Heavy Chevy" 402
1969 Nova 509
Old 10-31-2003, 03:45 PM
William William is offline
Default Re: Big Block Frame Mounts
Yes. All bb frame brackets position the engine approximately 1" to the right. If you intend to use a T400 you will also need the crossmember for it. Manual trans bb cars did use a different one than all sb but the sb crossmember can be re-drilled or use the later 1-bolt trans mount. You will also need the bb z-bar.
Be aware that '67-'68 brackets are not the same as '69. The '69 bracket is shorter and narrower, designed for the thicker interlocking motor mount. Problem is the '67-'68 motor mount will fit them causing all sorts of problems. Whatever you use the motor mount must be a tight fit on the bracket. If the fit is sloppy, with a 1/4 or so gap the mount is incorrect for the bracket.
Old 11-01-2003, 12:32 AM
William
Thanks for the information on the frame mounts I assume they are correct and for a 69 however I will get the motor mounts out and check the end clearance to be sure. I am installing a Merlin III block and a Turbo 400 with the correct transmission crossmember.
Again thanks for the help this is a great site the information is always helpful and correct.
Jeff
1969 Nova 509
