Old 10-26-2003, 11:56 PM
PxTx's Avatar
PxTx PxTx is offline
Default CE engine block data?
This afternoon I was helping my Pop clean out along his garage. One item uncovered was an old small block with a CE stamping.
Anyway, the here is what the block is
CE8-701 96
Casting # 3933180
Date Code- A128
My Pop said he remembered it as being a small journal 4" bore motor. It had a 327 crank in it, and is probably a 327 motor originally. The real reason I figured I would get some data on it is to possibly help out someone with an early Z28.
I don't know if this block would be applicable to a Z28, but if it could be used as an acceptable replacement block, then it certainly would be worth saving. Any input is appreciated!
Paul T
Paul III
