Old 10-23-2003, 07:20 PM
Default Camaro Block Stamping
Would like to know if I could get some opinions on the picture of a block stamp from a 396 out of a 68 Camaro? I'm wondering about the appearance of the stamp TI212MQ.
Any help would be appreciated.
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
Attachments - The Supercar Registry 54993-Block Pad.jpg 54913-enginepad_8N421077_T0411MQ.jpg 54908-68STAMP.jpg 54785-68 Camaro Block.jpg
Old 10-23-2003, 07:25 PM
Default Re: Camaro Block Stamping
Would it not be TO instead of TI ???? Very Questionable [img]/ubbthreads/images/graemlins/blush.gif[/img]
Jake is my grandson!!
Old 10-23-2003, 07:38 PM
allcamaro's Avatar
allcamaro allcamaro is offline
Unless the photo has been altered the stamp to me looks wrong.The numbers seem to curve down and then back up as to correct the line.I think all stampings as this should have been gang samped not one by one as this looks to me,but as I said thats only if no alterations were done to the photo,also the pad looks suspect.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 10-23-2003, 07:39 PM
I should add that the car has a build date of 12E. This would mean that the block should be stamped T1212MQ. The trans and rear are correct date stamped and coded.
Also, the partial VIN appears correct on the block to the right of the code. Just concerned about the I instead of what I think should be a 1. Maybe I'm splitting hairs, but any help is appreciated. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Old 10-23-2003, 07:40 PM
Belair62 Belair62 is offline
I had one of those MQ Camaro's...and it was NOTHING like that.
Old 10-23-2003, 07:42 PM
yountto yountto is offline
having a t1212 instead of t0212 is not the determining factor that this is an original pad or not..the 1212 is dec 12 [1967 in this case] and 0212 would be feb 12 1968 ..both from a 68
Old 10-23-2003, 07:43 PM
Jeff H Jeff H is offline
The "I" and "1" were interchangable due to a lack of stamps I guess. There are original motors with "I" in the place of a "1" so don't let that throw you. But the stamping doesn't look straight and spaced properly. Do you have a better picture with some more detail?
Old 10-23-2003, 07:49 PM
I'll do you one better. Here's the link to the E-bay listing.
http://cgi.ebay.com/ebaymotors/ws/eB...=6161&amp;rd=1
I'm sure that I'm not the only one checking it out anyway. [img]/ubbthreads/images/graemlins/haha.gif[/img]
Old 10-23-2003, 08:03 PM
I have a problem with the VIN stamping on the Muncie. All the 68 LOS Camaro Muncies I've seen have the VIN stamped on top and not on the side.
Martin Foltz
68 Camaro SS-396
Old 10-23-2003, 08:31 PM
MYSTERYCHEVELLE MYSTERYCHEVELLE is offline
If I could see that "CASTING CLOCK" a bit better on that Muncie case, it would help...might be able to see if it at least matches the build date.
The Block Stamp, and though I am not very familiar with Camaros....looks abit suspect...but not b/c of the "I" that is fine IMHO., but it just has an overall...amateur re-stamp look to it...hard to put my finger on it. Just my 3 cents. ( inflation )
