Old 10-19-2003, 06:29 PM
RED427 RED427 is offline
Default 302 motor
I FOUND A SMALL BLOCK ,CAST # 386,DATE I-12-8
VO913XI.IT HAS A 1178 CRANK,O RODS,302 PISTONS.
CAN NOT FIND XI CODE WHAT IS IT???? <font color="red"> </font> [img]/ubbthreads/images/graemlins/confused.gif[/img]
Old 10-19-2003, 06:50 PM
JChlupsa JChlupsa is offline
Default Re: 302 motor
Has a 69 302 crank and the block could be from a 302. Cant find the XI code either. I would contact Kurt S here and ask him if he knows if the export Z28's engine codes were marked different than the non-export cars. My thoughts with the X standing for export
Old 10-20-2003, 10:46 PM
jg95z28 jg95z28 is offline
XI = 1969 350 cid/215HP 2-bbl. [img]/ubbthreads/images/graemlins/thumbsdown.gif[/img]
Jeff
Old 10-21-2003, 02:33 AM
Hi Red, Probably some one got a 4" bore block and made a 302. What are you putting it in? Is it for sale? [img]/ubbthreads/images/graemlins/[/img] Thanks, Sam
Old 10-21-2003, 10:59 PM
CHEVY DID NOT BUILD 350-4 BOLT 215 HP FACTORY MOTORS IN 1969
THIS MOTOR IS ALL STD.! [img]/ubbthreads/images/graemlins/confused.gif[/img]
Old 10-21-2003, 11:25 PM
Looks to me that someone just got the 302 parts and built a motor. I have nothing against a 2 bolt 302 motor or any hi-po small block with 2 bolt mains. 2 bolt motors live a long time if done right. These DZ and 4 bolt blocks with the right casting #'s are getting out of hand. Overpriced! Sam
Old 10-22-2003, 02:08 AM
RPZ28 RPZ28 is offline
Red427
Whats the casting number on the center 3 main bearing caps? All 69 Hi Po small blocks used the 2482 nodular iron caps.
Ron
