Old 10-13-2003, 09:12 PM
JRSully JRSully is offline
Default Saving paint marks
Have all the original paint marks on my spindles, wondering what is the best solution to soak them in to get the 30yrs of grease and dirt off without taking the paint marks with it so I can doucment where everything goes when I re-apply them, any ideas appreciated. Thanks
71 Porsche 911 Targa
Old 10-13-2003, 10:28 PM
KENNY_PASCOE KENNY_PASCOE is offline
Default Re: Saving paint marks
HAD SOME BRAKE DRUMS WITH PAINT MARKS ON THEM BUT WANTED TO GET THEM LOOKING RIGHT. A FRIEND OF MINE OWNS A MACHINE SHOP AND I PUT THE DRUMS IN HIS HOT TANK AND THIS PROCESS LEFT THE PAINT MARKS INTACT. KP
1969 CAMARO SS 396/375 VAN T SOLD
1966 CHEVELLE SS 396/375
1969 CAMARO Z/28 ORIGINAL PAINT
Old 10-14-2003, 12:30 AM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
I would take pictures of them all in case the paint does come off. You can then re-apply if necessary.
Specialized Chevrolet Decals
Old 10-14-2003, 01:34 AM
ORIGLS6 ORIGLS6 is offline
Jim,
I'm cleaning the underside of my car and have found that Krud Kutter and Greased Lightning degreaser works very well. Also have used kerosene in a spray bottle for some of the undercoating and years or dirt and grime. Just take your time and use rags and soft tooth brushes and you should retain all the original paint marks. I even uncovered the original "XU" paper tags on my frame rails and kept them mostly intact with the kerosene method.
The crayon marks are a different story. You're on your own there!
Good Luck,
Dennis
Old 10-14-2003, 07:31 PM
Thanks for the help Folks, will utilize all of the above.
