Old 10-10-2003, 07:19 PM
brumie215 brumie215 is offline
Default 1967 - 68 Camaro 327 block ñ Misc.
I have a 1967 - 68 Camaro 327 2 bolt block w/main caps ñ cam is there
The Numbers are as follows VIOIOMA ñ Vin. # 18N326381 - Casting 3914678
It is + .030 on the bore. If I looked it up right ñ should be a 210 hp, manual transmission, built at flint ñ with October 10, 1967 date. 100.00 you pick up
Also have a pair of motor mounts/ box of bolts (head, oil pan, etc,) and coil bracket. 25.00
email me directly at [email protected] - block is in North Central Ohio
