Old 10-06-2003, 02:06 AM
DSYenko DSYenko is offline
Default 291 heads on L S 6's ?
Located a engine today.291 heads dated k 69 and early-mid 70,cant remember exactly.Date on 512 block date was absolutley unreadable. 163 intake.Could this have been a LS 5 or 6 or just a Monte Carlo pass car engine.Is there any chance that intake was used in 70 or did someone bolt it on?Dont know much else,the pad was machined to top it off.Just running it by those who would know,,, Thanks [img]/ubbthreads/images/graemlins/dunno.gif[/img]
EX 81 YENKO TURBO Z owner
Old 10-06-2003, 02:13 AM
LITTLE TOMMIE LITTLE TOMMIE is offline
Default Re: 291 heads on L S 6's ?
is the block a 2 bolt or 4 bolt main [img]/ubbthreads/images/graemlins/confused.gif[/img]
Old 10-06-2003, 02:32 AM
I wish I knew!! The engine was sitting on the floor in the back of an old shop so there was no way to tell.It's all a guessing game,Im just trying to see if there is even any possibility at all that it's a LS 6. Are the 291 heads good heads or just ho hum?
Old 10-06-2003, 02:44 AM
3964291....69-70...rect..CLOSED..396, 402, 427, 454, 109cc chamber
Large or small hex spark
plugs used [img]/ubbthreads/images/graemlins/scholar.gif[/img]
Old 10-06-2003, 02:48 AM
Why did'nt you ask me that before I drove 3 hours 1 way to look at it !!!!!!!! [img]/ubbthreads/images/graemlins/no.gif[/img]
Old 10-06-2003, 02:28 PM
You don't have to take off the oil pan to see if it has 2 or 4 bolt mains.Look at the area above the oil filter.
Look for two enlarged threaded outlets,to accept an external oil cooler.That would be a 4-bolt main block.
Old 10-07-2003, 02:51 AM
Thanks I remember seeing a oil pressure sender but cant remember if the rest is as you said or not.Thanks Duane
