Old 08-05-2003, 04:33 AM
Musclecarkid Musclecarkid is offline
Default PPG Glass Date Codes?
Anybody have a Chart on PPG Glass Date Codes? I have seen the LOF Chart but nothing on PPG.What do these numbers translate to? (70 Chevelle Convertible Side Door Glass)PPG Safety Plate...AS-2...27-30...DOT 18...M 7 8
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 08-05-2003, 05:23 AM
Kurt S Kurt S is offline
Default Re: PPG Glass Date Codes?
Best glass info source is Rich's article: http://www.camaros.org/glass.shtml.
Kurt S - CRG
Old 08-05-2003, 05:24 AM
musclecarkid;
Try here for the Normative Practices in First-Generation Camaro Window Glass from camaros.org as a start. Not much on PPG codes, but explains everything else.
AS-2 = "The stronger, 1/4-inch thick, AS-2 tempered glass was normally used in Camaro doors"
27-30 = What you need to know [img]/ubbthreads/images/graemlins/dunno.gif[/img]
DOT 18 = Manufacturer code PPG number is "DOT 18"
M78 = "model numbers to each type of auto glass, and each type received a different model number mark as required by ANSI Z26" M78 is proabably side door or quarter.
Greg
Old 08-05-2003, 05:46 AM
Ok, I read a ton on auto glass on CRG, but didn't see how to date code PPG Glass. So 27-30 is the date code? What does this mean? Maybe 27 = day, 3 = March, 0 = 1970.???? Anybody know if this is correct?
Kevin
Old 08-05-2003, 07:17 AM
Off the top, doesn't the -30 indicate the plant code it was made at?
Kurt S - CRG
Old 08-05-2003, 07:29 AM
I don't know what 27 30 means. I hope someone can figure this out.
Kevin
Old 08-06-2003, 08:11 AM
JoeG JoeG is offline
musclecarKid,
I pulled out two original side pieces of PPG glass that came off my '69 chevelle to check the code.The rt frt.PPG glass reads flow lite [27-29],the smaller rt.r.PPG reads flow lite[26-49]
Now I'd say it's a rating of the glass--at first I thought it was a light transmission rating, but then I found some info on [noise reduction ratings ]and [sound transmission class] on safety tempered glass ,and it's rated by thickness of glass, manufacturing process etc.---the rating system is similar[ 27-30 ]--[26-47]---[25-29] and so on.---Just some more info to kick around----JoeG
Old 08-07-2003, 03:33 PM
Aren't they still around??
They should have records on file.
Is it possible to stil contact PPG today and ask them what they mean?
Old 08-07-2003, 03:59 PM
Mr70,
Good idea----Oh yeah---copo9566aa/Roger said ,the Canadian Maple Leaf he painted on the side of your Chevelle is not permanent.
I Called PPG Rick, cust. service said first 2#'s = plant, second 2#'s= day/ month ------but they were thinking of changing over to noise transmission ratings : [img]/ubbthreads/images/graemlins/tongue.gif[/img]------- [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/beers.gif[/img]
Old 08-08-2003, 07:36 AM
Joe G,Are you saying 27-30 is: 27 = Plant Code and 30 = March 70? Or 3 = day and 0 = ? I'm lost!!Kevin
Kevin
