Old 07-18-2003, 10:44 PM
ssbrewskyaz ssbrewskyaz is offline
Default Let's try the Paint thing again
Can we run through this revised list again? I know I'm missing some key pieces. Feel free to add components to the list and I will incorporate into an attachment.
Ya know, until just now, it never occurred to me that some folks might want to keep this information a secret. But then again, it's not really a secret, it just involves scouring the internet until one stumbles across it.
Thanks for the input. ...SWB...
Ex ZL1 # 57 Owner
Ex RS COPO Owner
Current 70 Cortez Silver LS6 Owner
1970 GM A-Body Restoration Paint Colors
AC Blower Box Housing:
Natural dark plastic.
A/C Brackets:
Semi-gloss black
A/C Compressor:
Semi-gloss black
A.I.R Pump / Smog Pump:
Natural Aluminum
A.I.R Pump / Smog Pump Pulley:
A.I.R Pump / Smog Pump Tubes:
Alternator:
Natural aluminum finish, no paint or plating.
Alternator Brackets, Upper and Lower:
Most brackets were painted semi-gloss black, but there are exceptions.
Alternator Fan:
Zinc plated (silver).
Alternator Pulley:
Silver cad plated -or gold cad plated (depending upon the application).
Battery Box Hold Down Clamp:
Semi-gloss black.
Bellhousing:
Natural aluminum or partial engine color. They were painted with the engine, mostly to all orange.
Brake Distribution Bracket:
Cadmium dichromate.
Brake Lines:
Natural steel
Brake Line Clips:
Multiple choice, natural finish, black oxide, or zinc chromate (green) finish.
Clutch Cross Shaft:
Gray phosphate plate.
Clutch Fork:
Natural steel finishes that can be painted with cast-iron spray paint
Clutch Linkage Parts:
Gloss black finish.
Clutch Return Spring:
Natural steel or gray phosphate.
Clutch Return Spring Bracket:
Natural steel finish.
Control Arm Bolts and Large-End Washers:
Natural steel.
Control Arm Adjustment Shims:
Natural steel.
Control Arm Cross Shafts
Semi-gloss black enamel.
Crankshaft Pulley:
Semi-gloss black.
Disc Brake Dust Shields
Distributor
Natural aluminum with black plastic (bake-a-lite) cap
Driveshaft
Natural steel
Engine Accessory Braided Ground Strap:
Natural, no paint or plating.
Engine Dipstick Handle:
Engine Dipstick Tube:
Exhaust Manifolds:
This is another area where the GM divisions differed. According to restoration sources, Chevrolet exhaust manifolds were over-sprayed when the engine was painted. Whatever the case may be, if youíre going to drive the car, any over- spray that may be sprayed on the exhaust manifolds will burn off quickly.
Exhaust Manifold Locks:
The exhaust manifold locks were natural finish unless the exhaust manifolds were painted; then they were over sprayed.
Exhaust System / Mufflers:
Natural Steel
Fender Bolts, Fender Bolt Washers:
Black oxide.
Firewall:
As with the frame, there are many different formulas that can be used to achieve a semi gloss black paint to match the factory finish. Some restorers like to mix their own paint to get the shine they desire, but many restorers also use a premixed PPG paint for their engine compartment. PPG 9423 lacquer is about as close as you can get to the factory finish. A quart can is enough to do a complete engine compartment. Many of the spray can manufacturers (e.g. Krylon, VHT) make a semi-gloss black that also looks good on, engine compartment components if you don't have professional spray painting equipment. If you have spray equipment here's another custom lacquer formula that you can use:
2 qt. PPG mixing black #386
1 qt. universal flattening agent
1 qt. mixing clear #3 10
PPG DTL16 thinner
Floor Pans:
The assembly plants used a dark gray to black finish on the floor pans.
Frame / Sub Frame:
The frame and sub frame were painted semi-gloss black. Some restorers like the frames a little more on the shiny side, while others like a flatter finish. There are a lot of different formulas for this and different paints you can use. Most restorers use acrylic enamel or acrylic urethane finishes with a flattening agent for frame components because of their durability, One formula that you can use is as follows:
3 qt. PPG Delstar rnixing black
1 qt. flattening agent
PPG DTR601 quick-dry reducer
Front Springs:
Natural metal.
Front Spindles
Fuel Lines:
Gas Tank
Galvanized natural steel
Gas Tank Straps
Gloss black
Heater A/C Blower Box:
80% gloss IMO black. Generally, more shine than the engine compartment.
Hood Catch:
Components look like natural finish, but are gray phosphate plated
Hood Hinges:
Components look like natural finish, but are gray phosphate plated.
Hood Latch:
Hood Springs:
Hood Underside:
Horns:
Gloss black finish.
Horn relay:
Natural
Ignition Coil
Gloss black
Ignition wire dividers:
Black plastic.
Inner Fenders:
*See Firewall*
Intake Manifold:
Aluminum Manifold: Natural Aluminum with slight orange over spray at the cylinder heads.
Cast iron: Chevrolet orange
Master Cylinder:
Most of the GM cars came with natural finish master cylinders although some use gloss black. For the natural look, they can be painted with cast-iron gray paint; black should be Lower gloss black paint. Cheap stuff originally.
Master Cylinder Lid:
The master cylinder lid should be cadmium dichromate (gold rainbow cad.
Master Cylinder Bail Clips:
Natural metal.
Parking Brake Cables
Natural steel
PCV- Hose Clips:
Black oxide
Power Brake Booster:
All GM power brake boosters were cadmium dichromate.
Power Brake Hose Clips:
Black oxide.
Power Steering Pump:
Gloss black enamel.
Power Steering Brackets:
Semi-gloss black enamel. Some brackets may actually look like a cross between semi-gloss and gloss black.
Radiator:
Harrison radiators were painted Gloss Black. PPG Deltron gloss black acrylic urethane.
Radiator Cap:
Radiator caps were plated.
Radiator Fan Blades:
80% gloss, IMO, Gloss Black
Radiator Fan Clutch
Natural aluminum with a gold cadmium center. The clutch shaft and spring are natural finish.
Radiator Shroud:
Radiator shrouds should be left natural plastic. Some shrouds on early GM cars were steel and they should be painted semi-gloss to gloss black.
Radiator Support:
*See Firewall*
Rear Axle
Semi-gloss black
Rear Coil Springs
Gloss black
Rear Trailing Arms
Semi-gloss black
Rear Stabilizer Bar
Semi-gloss black
Shock Absorbers:
Gloss gray enamel.
Stabilizer Bar:
Depending upon the GM division, these can be natural or semi-gloss black.
Stabilizer Bar Brackets:
Depending upon the GM division and supplier, the brackets can be semi-gloss black or natural.
Starter Motor:
Starter Motor Support:
Steering Gearbox:
The cast-iron portion of the box is natural finish. The access lid is natural aluminum; the bolts are black oxide.
Steering Intermediate Shaft:
Natural steel
Steering Components, Tie Rods,:
Natural steel finish. These components can be painted with clear or cast- iron paint
Transmission
Natural aluminum
Transmission Support
Depending upon the GM division and supplier, the supports are Semi-gloss black or Natural steel
Trunk:
Trunk Latch:
Voltage Regulator Cover:
Gloss-black enamel.
Water Pump Pulley:
Semi-gloss black.
Windshield wiper motor:
Gloss black finish.
