Old 06-30-2003, 07:35 AM
ssbrewskyaz ssbrewskyaz is offline
Default 70 Chevelle Component Paint Restoration Detail
OK, That wasnít so hard after being pointed in the right direction. We're talking about 70 Chevelles. I realize there may be some plant specific exceptions, however, can we get a consensus, or in other words, ìpick the fly poop out of the pepperî on this. What if I put together a list of every conceivable part on the car, is there any interest in making a master list that everyone agrees on? I didn't think so, how about almost everyone. ...SWB...
AC compressor-semi-gloss black
Alternator- natural aluminum
Brackets and steel pulleys-semi gloss or gloss black
Brake booster-gold cadmium plated (master cylinder lid also)
Bellhousing-natural aluminum
Cast iron pulleys- natural cast iron
Clutch cross shaft - Semi-gloss black
Clutch push rod - natural steel
Coil- gloss black
Distributor- natural aluminum with gloss black cap
Driveshaft - natural steel
Fan clutch-natural aluminum
Firewall, inner fenders, radiator support-semi-gloss black
Frame and upper/lower control arms and upper shafts-semi-gloss black
Front coil springs-gloss black or natural (better detail contrast)
Front sway bar-natural cast iron gray
Fuel and brake lines-natural steel
Gas tank-natural steel (shiny)
Gas tank straps-gloss black
Heater or AC housing-semi-gloss black
Hood hinges, latch, catch and springs- gray phosphate plated
Horns- gloss black
Master cylinder- natural cast iron (some use gloss black)
Parking brake cables-natural steel
Power steering pump-gloss black
Radiator and fan-gloss black
Radiator shroud-natural black plastic or gloss black
Rear axle-semi-gloss black
Rear coil springs-gloss black
Rear control arms-semi-gloss black
Rear swaybar-semigloss black
Steering box-natural cast iron gray
Steering column shaft-natural steel
Steering linkage-natural steel
Transmission support- semi-gloss black
Transmission-natural aluminum
Voltage regulator-gloss black
Windshield wiper motor-gloss black [img]/ubbthreads/images/graemlins/scholar.gif[/img]
Old 06-30-2003, 12:36 PM
JLerum JLerum is offline
Default Re: 70 Chevelle Component Paint Restoration Detail
Is their not a book on these items for judging? example.. Like a Bloomington gold for Corvettes?
JIM [img]/ubbthreads/images/graemlins/dunno.gif[/img]
1970 LS-6 Chevelle
Going fast on Goodyear Polyglas.
12.21 @ 115.32 PSMCDR 2009
12.24 @ 114.30 PSMCDR 2010
Old 06-30-2003, 03:02 PM
Scott...Are you Home for a few days with nothing to do ? [img]/ubbthreads/images/graemlins/haha.gif[/img]
Old 06-30-2003, 07:38 PM
Kurt S Kurt S is offline
Default Re: 69-70 Chevy Component Restoration Detail
Your list is good for most 69-70 Chevys.
Many pulley were plated, not painted. Finishes varied alot.
Painted with engine, mostly to all orange.
Nope, galvanized.
Heater box should be a 80% gloss IMO.
AC housing is natural dark plastic.
Lower gloss black paint. Cheap stuff originally.
Radiator fan-gloss black
80% gloss, IMO.
Really? Not sure, I've seen natural, but the frame coatings were really quick to disappear.
Kurt S - CRG
Old 07-01-2003, 02:24 AM
Charlie,
Yes, the General forced me to take one of the two weeks of the two weeks that the plants shutdown. Don't ask me why, my account sure don't take it off. Any way, I'm deviding my time between the LS6 and the 63 SS to ease the pain...SWB...
[img]/ubbthreads/images/graemlins/beers.gif[/img]
