Old 06-19-2003, 07:59 PM
will will is offline
Default 67 camaro base coupe
FOR SALE
1967 CHEVY CAMARO
454 CU.IN. , TH400, 3.73 POSI
2 BOLT MAIN, BORED .030, 10 TO 1 FORGED PISTONS, RESIZED TRUCK RODS, CRANK TURNED 20/20, HIGH VOLUME OIL PUMP, 781 LARGE OVAL PORT HEADS PORTED, 2.065/1.725 1 PIECE SS MANLY VALVES, COMPCAMS DOUBLE ROLLER TIMING CHAIN, COMPCAMS ROLLER TIP ROCKERS, COMPCAMS PUSH RODS, AND GUIDE PLATES, CRANE 272H CAM AND LIFTERS, EDLERBROCK RPM AIR GAP INTAKE, 850 VS DEMON CARB, HEI DISTRIBUTOR, ACCELL HOT COIL, ACCELL 8.8 RACE WIRES, NEW STOCK WATER PUMP, ALT AND HOSES , NEW 4 CORE RADIATOR ,BB FAN SHROUD GM TURBO HYDRAMATIC 400, COMPLETE REBUILD, B&M SHIFT KIT AND 2500 HOLE CONVERTER, DRIVE SHAFT, NEW LINES AND TRANS COOLER, BB CROSS MEMBER
10 BOLT ALL NEW BEARINGS, NEW REBIULT POSI UNIT,
RICHMOND 3.73 GEARS, COMP ENG. TRACTION BARS,
NEW MONROE GAS SHOCKS
NEW GOOD MARK FRT FENDERS, HEADER PANEL, COWL HOOD, CORE SUPPORT, INNER FENDERS, FULL FLOOR, REAR 1 / 4 ëS, SHOCK TOWERS, ROCKER PANELS, GM REAR SPOILER, NEW GRILL, TRUNK DECK, HOOD LATCH, FRT SPOILER, EMBLEMS, DOOR HANDLES, LOCKS, BUMPERS, FRT PARKING LIGHTS,
SUB FRAME REMOVED CLEANED AND POR-15ed, NEW SUB FRAME BUSHINGS, COMPLETELY REBIULT FRT END WITH
PLOYGRAPHITE PARTS, SOLID 1î SWAY BAR, MOOG 6041 SPRINGS, MONROE GAS SHOCKS
FLOW MASTER AMERICAN THUDER SYSTEM, AND
HOOKER HEADERS
NEW SOUND DEADNER, NEW CARPET W/ JUTE, FRT SEAT RECOVERED W/NEW FOAM, REAR SEATS RECOVERED,NEW PACKAGE TRAY,FRT AND REAR DOOR PANELS, NEW ARM RESTS, NEW HEAD LINER, SAIL PANELS, DASH PAD, DASH BEZEL, RADIO FRAME, FLOOR MATS, HURST RATCHET SHIFTER, AUTOMETER GAUGES, AUTOGAUGE MEMORY
TECH, NEW SPEEDO CABLE, AFTER MARTKET SS STEERING WHEEL, NEW DOOR SILLS.
CREAM SICLE ORANGE WITH WHITE BUMBLE BEE STRIPE
ALL BASE COAT CLEAR COAT
STOCK POWER DISC BRAKES WITH NEW CALIPARS, BRAKE HOSES, AND BRAKE LINES, REAR IS STOCK DRUM IN GOOD CONDITION
NEW GAS TANK, SENDING UNIT, FUEL LINE (FROM TANK TO PUMP), NEW FUEL PUMP, SS GAS CAP, BF GOODRICH ON TORQUE THRUST DíS
FRONT 225/60/R15 ON 15 X 7 WHEELS
REAR 245/60/R15 ON 15 X 8 Ω WHEELS
LESS THEN 2000 MI ON TIRES ALSO HAVE AUTO CONSOLE, NEW SHIFTER PLATE FOR AUTO, USED AUTO SHIFTER,USED 4SPEED SHIFTER PLATE,REAR BRAKE LINES, DOOR WEATHER STRIPING, REAR SWAY BAR, AND OTHER MISC PARTS .TONS OF RECIEPTS, LESS THAN 1,000 MI ON ENTIRE CAR SINCE REBUILD $17,500 OR BEST OFFER or trade for a nice driver 69 camaro/nova
http://community.webshots.com/user/fastorange67
[email protected]
00 SS camaro
55 belair stockcar
68 chevelle 300
71 malibu (basket case)
