Old 06-01-2003, 09:15 PM
bbbenny bbbenny is offline
Default rear portioning valve info
looking for help, on the the rear portioning valve. i;m talking about the one that is on the unibody rail, under the drivers door. how do you decode the info on the body of the [img]/ubbthreads/images/graemlins/scholar.gif[/img] valve? can;t find any info on it???? thanks bbbenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 06-03-2003, 04:23 AM
Default Re: rear portioning valve info
bbbenny;
I believe it is juilain date and year. Can you post the numbers here or email me.
Also check out this thread on the use of it on the Nova in 70:Research Question:Brake Pressure Regulator
Also look here:Camaro Research Group Multi-Year Research Topics
Old 06-03-2003, 11:35 PM
NCGuy68 NCGuy68 is offline
bbbenny,
Good question. I've seen this valve only on 2 unmolested 68 small block SS Camaros with front disc and J52 suspension. Althought the CRG is open to info on it, I've always wondered about the numbers on it. And why was its use so sporadic?
Can anyone else chime in on this one?
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 06-04-2003, 02:27 AM
chevy 114270, your correct about the [img]/ubbthreads/images/graemlins/[/img]numbers on the pressure reg. i have two regs, i just didn;t put two and two together???? the numbers are. 274-8 and 211-8. simple enough when you know what your looking at. thank you all for the help. hope i can help someone one day. bbbenny
Thanks Benny
Old 06-04-2003, 03:06 AM
bbbenny;
Your welcome, glad I can help!
Old 06-06-2003, 04:28 AM
SS4Real's Avatar
SS4Real SS4Real is offline
Did 1970 Chevelle's with front disc/rear drum also have this valve? My front brakes are fine, but the rear brakes frequently lock up since I had the power booster removed and reinstalled when it was replated. How is this adjusted?
Jim
Old 08-03-2003, 07:20 AM
Musclecarkid Musclecarkid is offline
The rear brake pressure valve was standard on all 70 Chevelles with factory front disc brakes. There were 2 designs available. Early 70 (actually 69) built cars used a valve with an "N" stamped on it. After 12-23-69 it was replaced with an "S" stamped valve. The "N" was rated at 250psi and the "S" was 400psi. Also all 70 Monte Carlos came with this pressure valve because they all had front disc brakes. The difference between the Camaro and Chevelle valves is the mounting bracket is reversed to allow a different mounting position. I have 5 of these dated from 260-9 "N", 022-0 "S", 023-0 "S", 079-0 "S", and 127-0 "S". I'm sure most other 1970 GM A-Body cars used this as well. Some early Camaros with AC and Disc Brakes or Big Blocks also may have one. All 70 Z/28 and T/A's had a simular valve bolted to the distribution/brake warning valve under the master cylinder. Most of the pressure valves I have are dated about 2-4 weeks before the build date of the vehicle.
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 08-03-2003, 09:41 PM
JoeG JoeG is offline
musclecarkid,
Good info---Thanks [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]--JoeG
Old 08-04-2003, 02:19 AM
Thanks Joe G, I really researched that little rear brake pressure valve. GM found it necessary to use that valve to eliminate rear wheel lockup in a panic stop. In 71 GM replaced the front metering valve, the rear pressure valve, and the brake warning switch with a one piece combo valve mounted on the left front frame rail on A-body and under the master clyinder on F-body cars.
Kevin
Old 08-04-2003, 04:16 AM
Kevin,
research must be your middle name! Very good information, thanks for sharing. [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
