Old 05-09-2003, 07:44 PM
mike32 mike32 is offline
Default FULL-SIZE BIG BLOCK FRAME MOUNTS
I AM INSTALLING A BIG BLOCK IN A 1969 FULL-SIZE AND WAS WONDERING IF I NEED TO CHANGE THE FRAME MOUNTS OR WILL THE STOCK SMALL BLOCK MOUNTS WORK? SOMEONE HAS TOLD ME THE ENGINE MAY SIT BACK TO FAR WITH THE SMALL BLOCK MOUNTS, AND COULD CAUSE CLEARANCE ISSUES WITH THE POWER BRAKE BOOSTER. ANY THOUGHTS OR ADVICE?
THANKS
MIKE
MIKE
Old 05-09-2003, 07:55 PM
Chevy454 Chevy454 is offline
Default Re: FULL-SIZE BIG BLOCK FRAME MOUNTS
I've "heard" you can use the small block frame mounts in a Nova and get away with it. Something about setting the engine back and better weight transfer or something...[img]/ubbthreads/images/graemlins/naughty.gif[/img]
I'd say there should be plenty of room in a big car, but I'm sure someone else here knows for sure.
Old 05-09-2003, 08:59 PM
L78biscayne's Avatar
L78biscayne L78biscayne is offline
i have done 4 of these it just bolts in [img]/ubbthreads/images/graemlins/beers.gif[/img]
1967 bel air 5.3 4l60e
Old 05-09-2003, 09:42 PM
THANKS GUYS.
MIKE
MIKE
