Old 04-30-2003, 04:25 PM
Chevy454 Chevy454 is offline
Default Oil pans
Will a BBC Corvette or Chevelle pan work in a 1st gen Camaro?
Old 04-30-2003, 05:19 PM
Default Re: Oil pans
The Corvette will not. Not sure on the Chevelle pan. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 04-30-2003, 05:29 PM
Figures...I'm wanting to put on a windage tray, but I haven't found one that works with the standard 4-quart Camaro pan. I've heard you can make 'em fit, but was hoping their was an easier way.
Old 04-30-2003, 06:12 PM
If it's a tri-stepped pan, as in to say shallow at the balancer end, then a 2nd stage deeper in the middle, then sump in the rear it will not. I think these are big car (Impala, Caprice) pans I'm thinking of though, I had one of these and tried to put it in a '70 Chevelle, and the second step in the middle of the pan hit the crossmember before the mounts would line up. I think if you're putting a big block in a 1st gen Camaro, the pan needs to be the type that has a smooth transition from front to sump, no slightly deeper portion in the middle or it'll hit the chassis. I'd say if it's a stock, smooth transition Chevelle pan it should work though. Avoid those big car pans...not good for anything but big cars.
Old 05-01-2003, 07:15 PM
Your local chevy dealer has a pan for school buses that is 7 qt and will work Kim [img]/ubbthreads/images/graemlins/scholar.gif[/img]
Jake is my grandson!!
Old 05-01-2003, 07:28 PM
sYc sYc is offline
Wow, yellow oil pan, that will match the car. [img]/ubbthreads/images/graemlins/haha.gif[/img]
Tom Clary
Old 05-01-2003, 11:35 PM
They cummmm black [img]/ubbthreads/images/graemlins/haha.gif[/img]
