Old 04-23-2003, 04:00 PM
NCGuy68 NCGuy68 is offline
Default Stamped engine numbers?
Two sets of stamped numbers on the right front block pad in front of the head. Small block Chevy:
1st # VO424HT
2nd # 8F20388
Sorry, I couldn't see the block casting # or date code.
Can anyone decode these?
Thanks for all help.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 04-23-2003, 07:42 PM
Jeff H Jeff H is offline
Default Re: Stamped engine numbers?
I found the HT to be either a 327/350 hp Corvette engine or a 350/255hp full size engine. I think the VIN indicates a full size chevy, not Corvette.
Old 04-23-2003, 10:07 PM
Thanks for your help Jeff. I also found that the HT code appeared on 65-67 'Vettes' as a 327/350 RPO L79.
The motor is in a 56 Chevy which is for sale. It does have a duel snorkle chrome air cleaner which is vintage.
Can anyone else chime in on this one?
Craig S.
John Force.
Old 04-23-2003, 11:12 PM
JChlupsa JChlupsa is offline
1968 Big Chevy Passenger car if it were a Vette it would be 8Sxxxxxx S standing for the St Louis Plant
Old 04-25-2003, 01:51 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Full size chevs were also built at St Louis. The "F" in the VIN derivative means Flint Assy Plant which built Full size chevys and confirms this block is out of a full size chev.
Old 04-25-2003, 02:08 AM
Norm reynolds Norm reynolds is offline
Also full size chevy used a Q-jet carb were the vette L-79
used a holley carb
Old 04-26-2003, 03:35 AM
Gents,
Thanks for your replys. The motor does have a casting # 3795397 alumium intake manifold which seems to be a 62 Vette with a Rochester 4-BBl carb. I realize parts can be changed thru the years. Trying to determine if this motor is a 'diamond in the ruff' and worth saving.
Craig S.
John Force.
