Old 01-26-2003, 06:48 AM
Default Hose Clamps
Hello,
Are these style hose clamps available? Thanks, Greg
Old 01-26-2003, 02:29 PM
Default Re: Hose Clamps
Greg,
Yes they are from many sources. If you want exact, be advised they are not plated exactly the same and do not have date codes stamped in them. Other than that they look great.
Old 01-26-2003, 03:36 PM
RonNova396L34 RonNova396L34 is offline
Greg,
If you need some, Show Cars is right where I live so I could find some for you or I can give you their number. You have mail.
Ron [img]/ubbthreads/images/icons/grin.gif[/img]
Old 01-26-2003, 04:40 PM
SS427,
I understand about the plating and the date codes. I am more concerned with the correct shape. I have seen plenty of the one on the left. I have not seen the one I need on the right. Note the higher tower on the right. So are you saying that the higher tower style is available? Thanks, g
Old 01-26-2003, 05:00 PM
shor shor is offline
doesn't the tower go up while you turn the screw?
Old 01-26-2003, 05:41 PM
Stefano Stefano is offline
Correct style clamps with or without date codes are available at www.DRClassic.com Shor,yes both the clamps shown are similar, one just hasn't been used yet.
Old 01-26-2003, 06:45 PM
Wittek MfG. in Chicago was one of the companies that made these Originally.
Old 01-27-2003, 03:05 AM
Shor,
Ok, Brain was not engaged all of the way last night. [img]/ubbthreads/images/icons/confused.gif[/img] What threw me was the hole punched in the side. I think the new ones I have are cheap replacements. I will order a set of the Wittek ones. Thanks!
