Old 11-26-2002, 03:44 PM
Jeff Murphy Jeff Murphy is offline
Default Fan belt on non-A.I.R. L-72?
What is the right fan/alternator belt part number for a 69 L-72 Camaro running without the A.I.R. system installed? I'm assuming some of you Yenko/ZL-1 guys with headers are running your setups this way...
Jeff M.
ZL1 #49 (Dale, Waukesha WI) Super Stock restoration by SCW; 9561AA (Walters, Hebron OH) Super Stock motor by the Grump
Old 11-26-2002, 09:03 PM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
Default Re: Fan belt on non-A.I.R. L-72?
I'm running my manual tranny 69 L89 that way. Can't say I know the specific part number, but you could probably go with a belt applicable to "396CI/325HP L35 Automatic Tranny" which I believe did not come with A.I.R.
Just my $.02 worth, hope it helps.
Specialized Chevrolet Decals
Old 11-26-2002, 10:45 PM
Go with the Quanta belt# B-589C..$25.00.
I used it on a similar application as yours.
1-800 BELTS-88
Old 11-27-2002, 12:49 AM
bkhpah bkhpah is offline
If your L/72 has any grunt at all it will make a mess of the Quanta belts. I was told by Quanta that the belts are for show only. I went through a few...BKH
Old 11-27-2002, 03:41 AM
GarnetM20;
I do not know if this will help you but, the Parts book says:
Years USAGE............................................. ...............PART NO DESCRIPTION
69.... CAMARO (8 CYLINDER) (exc. AT., C.A.C., 302,396) 3883248 Generator
69.... CAMARO (8 CYLINDER) (396 w/A.T.)....................3937790 Generator
Which is not really the application and no 427 Camaro listed [img]/ubbthreads/images/icons/grin.gif[/img] so here is some more info from the parts book:
3883248 FAN AND GENERATOR 3/8"-47 1/2" CAMARO w/Sp. H/Per. (396)
3937790 FAN AND GENERATOR 3/8"-45 1/2" CAMARO w/H/Per. (396)
3937790 was also used for:
CHEVELLE (396.400 w/4BC, 454) (exc. Sp. H/Per.)
CHEVELLE (8 CYLINDER) (T.H. 400 w/H/Per.) (exc. 63 amp.)
PASSENGER (8 CYLINDER) (396, 427) (w/T.H. 400)
3883248 was mostly used for other small block applications.
Greg
