Old 10-10-2002, 10:52 PM
k92 k92 is offline
Default carburetor
Does anyone know what application this particular carburetor was for?? Here are the numbers on it... 3923289 DZ List 4053 704.... Also what about a distributor with the numbers 1111478 8c27? Thanks.
Old 10-10-2002, 11:48 PM
L78Impala L78Impala is offline
Default Re: carburetor
k92,
As per "Chevy by the Numbers", the Distributor is for a 1968 327 X 325hp. The 8c27 must be the date code 1968 March 27th.
The carb is for a 1968 high horse ( Z28, L78 or L72)engine. This carb could also be used on a 1969 Z28. The carb has been rereleased by holley, so it's best to check the date code on the air horn.
Hope this helps.
1965 Impala (L78)
1965 Riviera GS
http://www.impalass427.com/72res/MVC-001F.jpg
Old 10-11-2002, 12:00 AM
T Billigen T Billigen is offline
Looks like carb for a 1968 Camaro: 302(Z28) 396(L78) 396(L89) in the 375 HP. Do you have the number right for the distributor? is it 1111487? this is for 68/69 camaro with the 350 cube engine.
1968 COPO/YENKO 9737 Non-Converted
Old 10-11-2002, 04:07 AM
k92 k92 is offline
The dist. # is 1111478, it was laying with a bunch of other parts,, I thought that the date code was the 704 on the air horn?? What is the carb worth? It's all there,but needs rebuilt.
