Old 05-31-2002, 08:09 AM
Default L78 cam specifications
can someone post the specs on a L78 396 375hp camshaft,I know it was solid lift but I need the lift,duration and lobe seperation and any other information on one
Thanks
Bobby
Old 05-31-2002, 08:40 AM
JChlupsa JChlupsa is offline
Default Re: L78 cam specifications
Hope this helps:
1966 = 396/375 HP-M lifter/.520 intake lift/.520 exhaust lift//336 intake duration//336 exhaust duration//1.70 rocker ratio//3863143 part number//3863144 casting number//OMO casting symbol
1967 = M-lifter//.520 IL//.520 EL//316 ID//302 ED//1.70 RR//3904362 PN//3904366 CN//OMO CS
1968 same as 1967
1969 = M lifters///.520 IL//.520 EL//316 ID//302 ED//1.70 RR//3863143 PN//3863144 CN//OMO CS
From Chevy by the Numbers 65-69
Old 05-31-2002, 12:11 PM
You can still buy the cam from GM complete with lifters.
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 05-31-2002, 01:40 PM
Chevy454 Chevy454 is offline
Ahh...I see you made it on, Pete!
Who makes GM's cams? Crane?
Old 05-31-2002, 03:15 PM
I'm a slow learner, but here I am. Yes, Crane makes the GM cams.
peter
Owen Simpson
Eric Simpson
Old 05-31-2002, 03:35 PM
JoeC JoeC is offline
you can read the cam specs on the Crane web site
Old 05-31-2002, 03:57 PM
Good thinking, Joe.
Here is the cam card on the L-78/L-71/L-72/LS-6 cam:
http://www.cranecams.com/master/apps...m#5. Blueprint
