Old 05-18-2002, 05:07 AM
Nicola Nicola is offline
Default 69 L78 Nova Fan
What type of fan was used on a 69 L78 Nova ?
I have seen a 4 blade non-clutch fan and a 772 7 blade clutch fan mentioned not 100% sure ?
Attachments - The Supercar Registry pip.jpg Alternator and fan install resize.jpg 109.JPG 108.JPG
Old 05-18-2002, 11:02 AM
bkhpah bkhpah is offline
Default Re: 69 L78 Nova Fan
I have seen only a 4 blade non clutch setup on early cars and then a switch to a 5 blade non clutch set up later in the year. I have never seen a 772 clutch style used on a L/78 Nova. Ask Rowdy Rat to help out too..BKH
Old 05-19-2002, 02:18 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
I have a March built 69 L78 Nova...It has a five blade fan.
Old 05-20-2002, 05:15 AM
Thanks for the info my car was built in May 69 so I assume it would have a 5 blade fan. Do these fans have a part # and a date code ?
Old 05-20-2002, 01:35 PM
I am unware of any #'s on those blades...BKH
Old 06-26-2002, 12:45 PM
Yenko Paid Member
Nick
Found the P/N on the 5 blade fan on my 69 Nova L78.
It's 3947824EV Can't confirm its the original however.
Martin
Old 07-03-2002, 03:46 AM
Martin,
The 3947824 was replaced Mar of 1970. The 1970 L78 fan switched back and forth with 2 different part numbers for a 5 blade fan. Which is typical depending on the source of the part. Have you check an assembly manual for 69?
PART NO DISPOSITION Replacement DATE changed Page
3947824 USE 3976060 3-70 120
Greg
Old 07-03-2002, 02:26 PM
Greg
Those part#'s you are listing,are not Fan part#'s.
*3947824 is a 1969 Assembly line B/B Deepgroove Fan Pulley.Used on Special Hi-Perf solid lifter engines.
*3976060 is a 1970 Assembly line B/B Deepgroove Fan Pulley.Used on Special Hi-Perf Solid lifter engines.
The Fan is a different part # altogether.
Old 07-03-2002, 02:41 PM
I'll take a few of those ...6060 AP's pulleys please!!
they were used on the Deuces. [img]/ubbthreads/images/icons/grin.gif[/img]
Old 07-03-2002, 05:19 PM
Mr70,
Well, I guess it was late. I just looked up the number Martin listed "It's 3947824EV" in the prevoius note, in the parts number history DB. When I looked at the 1970 Assembly manual. I saw the two other numbers I mentioned. I should have quoted them. They are 3939001 and 3947128. If I would have looked closer I would have seen the 6060 was listed above the blade.
Greg
