Old 04-01-2002, 11:30 AM
T Billigen T Billigen is offline
Default M-21 Tranny tag?
I have the original transmission for my 69 Yenko Camaro, I am told there is a metal tag that is supposed to be attached by one of the bolts. Does anyone know what this tag represents and the number that goes on it? Tranny is a M-21 close ratio
1968 COPO/YENKO 9737 Non-Converted
Old 04-01-2002, 11:44 AM
Default Re: M-21 Tranny tag?
The tag has the part number for the complete assembly and the 2 digit letter code such as "WO" which would be M-22. The letter code can be found on the build sheet. I do not have my books accessable at the moment for the part number and code for the M-21. Perhaps others do. I have usually found the tags attached on one of the bottom bolts of the side cover.
Old 04-01-2002, 04:21 PM
Stefano Stefano is offline
Shor,
Your Douglass Yenko appears to have the original trans tag, you should compare it to Billigen's. I have never seen a Yenko Camaro Build sheet, do they exist?
Old 04-01-2002, 07:10 PM
Obviously Yenkos did not have their own build sheet. What I was trying to say, since I do not have my build sheet file with me, just look at another build sheet with an M-21 for the 2 letter code.
T Billigen, I may have a used tag at the shop and will check and gladly send it to you if it is the right part number and code.
Old 04-01-2002, 08:10 PM
I would sure appreciate that, if you have it let me know, Iwill e-mailyou my address...Thanks
Old 04-01-2002, 11:24 PM
Sorry, what you need is a tag with the WL code after the part number. As it turns out, that is not the one I have. I have seen these for sale in the past but not sure from whom. Perhaps Larry Patten?
Some of the tranny guys over at Team Chevelle can also be of assistance as many of them have extra tags.
Old 04-01-2002, 11:43 PM
shor shor is offline
mine is # 3946798..What do the #'s mean?
there are no letters on my tag
[Edited by shor (04-01-2002 at 06:43 PM).]
Old 04-02-2002, 12:44 AM
I just talked to a fellow with an nos muncie M-21 with the tag in place: 3946798 but no letters after the number?
Old 04-02-2002, 12:45 AM
THERE IS ONE OF THOSE LIL OLD TAGS ON E BAY,SAW IT LAST NIGHT WHILE CRUISING THE SITE,IT WAS UNDER MUNCIE,DON'T REMEMBER WHAT CODE WAS ON IT THOUGH
Old 04-02-2002, 12:49 AM
E BAY #1817650229
TAG READS 27AF
SL73A75 5C12
