Old 03-23-2002, 10:26 PM
funace funace is offline
Default pontiac head conversion
i have a 1978 pontiac 400 HO. it came with 6X heads. i have been told that they are a 101 cc head.
i want to get the most performance with spending the least amount of money. i also do not want to exceed
a 10:1 compression ratio. what i have been told to do is get a set of heads with a 72 cc combustion chamber
and that will boost my compression ratio and give me much greater performance.
if i should do this what heads should i use? and am i going to be able to get them at a salvage yard?
also i wanted to know if any of the hardware from the 1978 6X heads would swap out into any other pontiac
heads with smaller combustion chambers. i do not want to just get rid of my 6X heads because i put around
$400 into them about 2 years ago.
my last question is should i just drop the compression increase idea and buy a edelbrock intake or a
performace ignition?
Any help will be much appreciated!
Old 03-24-2002, 01:35 AM
Chris396 Chris396 is offline
Default Re: pontiac head conversion
Try this site.
http://performanceyears.com/cgi-bin/...ultimatebb.cgi
Old 03-24-2002, 03:29 AM
Rick Rick is offline
72cc Pontiac head castings:
1967 number: 670
1967 number: 97
1968 and 1969 numbers: 62 and 16
1968 number: 31
1969 number: 48
1970 numbers: 12 and 13
Rick
1967 Fitch Firebird
Old 03-28-2002, 10:37 PM
bird of a different motor bird of a different motor is offline
1969 16's and 62's will work also
