Old 02-21-2002, 02:06 AM
ssl78 ssl78 is offline
Default 69 Z-28 question
I am looking at a 69 Z-28. The ser# is 124379N680884 and the build date is 05A is the sequence # match the build date also it has a 6 redline 7 grand tach I thought that tach only came in early cars what would be the cut off for that tach.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 02-21-2002, 02:27 AM
Stefano Stefano is offline
Default Re: 69 Z-28 question
Does this Z28 have DF or YH coded wheels?
Old 02-21-2002, 02:32 AM
I have not picked it up yet so I am not sure.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 02-21-2002, 02:41 AM
Jeff H Jeff H is offline
That VIN doesn't look right for 05A. VIN 680xxx should be an 09A car. Double check that cowl tag, it could be a tag swap. Does it have the original engine/trans to verify it's a real Z28? If you're going off the cowl tag, definitely check it again.
Old 02-21-2002, 02:43 AM
Kurt S Kurt S is offline
Yes, it should have the 6x8 tach since it's a late car.
Post all the tag data and we'll see what #'s line up.
Kurt S - CRG
Old 02-21-2002, 03:50 AM
The only trim tag info I wrote down is
712 61 61
05a x-77
So I know the tag is for a burnish brown black interior standard Z-28.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 02-21-2002, 04:21 AM
Maybe this tag belongs to the other "Burnished Brown" 1969 Camaro mentioned previously on this sight? It certainly doesn't belong to your Camaro.
Old 02-21-2002, 10:10 AM
Norm reynolds Norm reynolds is offline
How can you tell the build date by the vin ??
STILL learning
Norm
Old 02-21-2002, 12:24 PM
CRG has a database they used to correspond the VIN to the month it was built. Jerry MacNeish's book also breaks down the approx time frame when a VIN what built. Check the rivets that hold the trim tag to the firewall, if they look like they've been messed with or if they look like hardware store rivets, then the tag has been swapped for sure.
Old 02-21-2002, 02:32 PM
Though the NOR body # would help confirm it, it does look like the tag or VIN has been swapped.
Kurt S - CRG
