Old 02-19-2002, 02:57 AM
hugger1 hugger1 is offline
Default Sub Frame question ?
Can someone please tell me the correct demension for the body bushing holes on the sub frame for a 69 . ?
Are the 2 front mount holes the same as the 2 rear mounts holes?
I just had my subframe blasted and although it is in good condition , the body mount holes are opened up.
I already made plates just need hole sizes.
THANKS in advance.
Jeff
Old 02-19-2002, 03:45 AM
Default Re: Sub Frame question ?
The firewall mount and rear mount holes measure 1 1/2". The core support holes are 7/8"
Old 02-19-2002, 02:25 PM
Thanks for the help SS427.
I really enjoy this site .
there are some very knowledgable people here and after talking to a few , very friendly and helpful to.
Old 02-19-2002, 09:52 PM
Not sure how big these "plates" are you made, but genrally if you buy the correct size washer from a hardware store, all you have to do is weld them in place and grind down the weld. The hole then is perfect.
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 02-20-2002, 03:52 AM
Thanks COPO Pete .
I made a template of the top of the mounting perch and cut them to fit ( using a plasma cutter , then tacked the right & left together and ground edges so they are the same.
Its all Mig welded and ground down so it looks right.
Used a Hole saw to cut correct size for bushing and then drilled the aligning hole the correct size as well.
The washer would have been easier though.
