Old 02-08-2002, 12:33 AM
redbaron redbaron is offline
Default 69 396 ss camaro
Hello all
Can anyone tell me if any 69 396 ss camaro came with a 10 bolt rearend. I'm a new member and sure like this site. Have loved yenkos and copos for years, just not rich enough to own one yet! Thank You
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
69 Ls7 T56 Camaro Project
Old 02-08-2002, 01:30 AM
Stefano Stefano is offline
Default Re: 69 396 ss camaro
Anything is possible, but it is very unlikely. I have howeve,r seen an early 1967 SS 350 A/C car with a 10 bolt non posi which was coded correctly and believed original.
Old 02-08-2002, 01:50 AM
Thanks Stefano
I was sure that was the case. I'm looking at a car that appears to be an original 69 396 SS, but it does have a 10 bolt.It has the right hood,heater core,etc. Thanks Again
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 02-08-2002, 02:58 AM
Rat_Pack Rat_Pack is offline
I would question it as I have not seen a big block Camaro with a 10 bolt from the factory until 1971. Check the stamping on the rh axle tube on the leading edge. Contact the CRG at www.camaros.org and give them the information. They can help you the best. It is possible that it is an SS396 but that the rear end has been changed..................RatPack...............
Old 02-08-2002, 03:30 AM
Thanks RatPack
The car has a nom big block in it now, but a 69 396 also comes with the car. Can anyone help me on the stamped and casting numbers info. Much appreicated.
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 02-08-2002, 03:45 AM
bkhpah bkhpah is offline
Check out the rear leaf springs. Five leaf is what I would expect...BKH
Old 02-08-2002, 03:50 AM
Thank You BKH
The car does have the 5 leaf springs.
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 02-08-2002, 04:01 AM
JoeC JoeC is offline
is there an X code on the trim tag?
Old 02-08-2002, 04:22 AM
Thanks Joe
Not sure, but will know tomorrow or Sunday.
Hopefully it not an early production model without the x code.
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
Old 02-10-2002, 06:14 AM
Hello
Looked at the car yesterday. It actually had a 12 bolt and it is a true X66 car. And now it's mine,I almost feel almost good as good as Charlie does with his 67 Pace Car.
Thanks to all for your help.
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
