Old 06-05-2001, 01:42 PM
Allen Allen is offline
Default Delco alternator decoding
Hi! I'm looking for some assistance decoding an original GM Delco alternator that I have. Vehicle application, model year, and anything else that can be deciphered would be appreciated.
A good source for information might be that "Chevrolet by the Numbers 65-69" book. I have the '70-75 version, but the alternator number is not listed in there. I suspect this one is a '69.
Any information would be appreciated. Thanks!
Below is what is stamped in the housing, as best as I can read it.
H 63A
1100774
9F23 12VNEG
I'm assuming that it may be a '69 model alternator, but don't know what it was used on. I plan to have it tested, and then possibly make it available for sale (assuming that it isn't correct for my own Nova!) for someone who might need a "correct" date-coded part for their restoration.
Allen
Old 06-06-2001, 06:18 AM
bbdon bbdon is offline
Default Re: Delco alternator decoding
I have looked in my copy of CBTN 65-69 for you. 9f23 seems to mean June 23rd 1969
The 63a tells us that it is rated at 63 amps.
Alans book does not list this number, and it shows no application for a 63 amp alternator on a Chevrolet passenger car for 69. It may be a shortcoming of Alan's book, but possibly it means that the alternator is for a truck or for a different GM division. I also looked in the 69 Shop manual, and the number is not listed in there either.
Old 06-06-2001, 12:23 PM
Thanks for checking. Could it possibly be a B-O-P type alternator? If yes, where would be a good source to look?
It does work fine, though - I had it tested.
Allen
Old 06-17-2001, 11:47 PM
elcamino elcamino is offline
My interchange book shows 1100774 as a 1967-70 Buick alternator. It says its a 55amp though?
NEW cars I had..
66 Impala SS396
70 Chevelle SS 454
72 El Camino SS350
73 Chevelle SS350
Old 06-19-2001, 02:04 AM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
Allen,
Here is some info you may be able to use
1969 Nova Alternator P/Ns (From Assembly Manuals)
V8 Man/Air 1100845
V8 Auto/Air 1100843
L4,L6 1100836
L78 396 1100834
My L78 Has the following info stamped on it
8J28 12VNeg
1100837 37A
Also has CZ stamped on housing. Mine may not be correct????
Martin
Old 06-19-2001, 12:20 PM
El Camino,
Thanks! You are the first person to actually say that they have found that number. I've been looking at the stamping, and can't seem to decide if that last digit is a "4" or a "1".
Does your book show a 1100771? If yes, what is it. Thanks a bunch!
Martin,
Thanks for the information. Did you get your dash lens replaced?
Allen
