Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 05-12-2001, 02:41 AM
Chevy454 Chevy454 is offline
Default New UBB code!!!!
Ok, I added some new ubb code, so now the board will be a little bit easier to use.
Here is the new code:
<UL TYPE=SQUARE>
*Automatic URL: anytime a URL is typed, it is converted to a "hot" link. EXAMPLE: www.yenko.net
*URL=: you can use this code to link words/text. EXAMPLE: the supercar registry
*Code: use this to insert code as it appears in .txt files. EXAMPLE: *List: this is handy when inserting a list of items. EXAMPLE: the list used in the post you are reading!
*Color: you can change the color of text using html color codes. EXAMPLE: <FONT COLOR="#800000">COLOR</FONT c>
*Center: pretty self explanatory, it centers text or images. EXAMPLE: <center>CENTER</center>
*Underline: underlines text. EXAMPLE: <u>UNDERLINE</u>
*Font: changes the font of the text: EXAMPLE: <FONT face="Amazone BT">FONT</FONT f>
*Size: changes the size of text. EXAMPLE: <FONT size="20">SIZE 20</FONT s>[/list]
For info on how to use this new code in your message, simply click "UBB Code is ON" to the left of the message box where you type a message, and a page will pop up. That page will explain how to use the new code! ENJOY!!!!
