Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 09-18-2000, 08:50 PM
Default Attach photos
Tom/Rob/Doug;
How do you attach photos to a post?
Old 09-18-2000, 09:15 PM
Chevy454 Chevy454 is offline
Default Re: Attach photos
M:
Check out this page for all of your posting info: https://www.yenko.net/ubb/ubbcode.html
If you will look to the left of the box where you type your message whenver you reply to a message or start a new topic, you will see it says *HTML is OFF *UBB Code is ON. If you will move your cursor over the part that says *UBB Code is ON, then click on it, you will come to the above page. ENJOY!
Old 09-20-2000, 02:35 PM
CHECK IT OUT!!!!
<IMG SRC ="http://albums.photopoint.com/j/View?u=378134&a=2797405&p=28682205&Sequence=0&res= high">
[Edited by sYc (09-20-2000 at 08:35 AM).]
Old 09-20-2000, 02:58 PM
OK M, here is how you have to get pics from your photo album.
Go you to your photo album, and select which category you would like to enter (eg. "marlin"). albums.photopoint.com/j/AlbumList?u=378134
Now, you have a list showing the pictures in "Marlin". albums.photopoint.com/j/AlbumIndex?u=378134&a=2797405
Click on the picture you would like to view (eg. "cg70yn.jpg") albums.photopoint.com/j/ViewPhoto?u=378134&a=2797405&p=28682209
Now, once that image is brought up, click on it one more time to bring up the high resolution image. albums.photopoint.com/j/View?u=378134&a=2797405&p=28682209&Sequence=0&res= high
Now, grab the URL of that picture and use either the UBB code or HTML image tag to insert it. Either one will work...the key is to use the URL of the FINAL IMAGE (the high res. version).
GOOD LUCK!
[Edited by Chevy454 (09-20-2000 at 08:58 AM).]
Old 09-20-2000, 03:29 PM
thanks,
It looks easy, I am going to try it.
take #51!!
M
Old 09-20-2000, 03:46 PM
JoeC JoeC is offline
hang in there Marlin....I'm waiting to see your photos. If you want to check the url you can right mouse click on the photo and click 'properties' and it will show the url of the photo
Old 09-20-2000, 03:52 PM
JoeC:
I had tried that as well, but found out that the file 'type' was undefined, even though I had it tagged as a jpg. I went back and forth with photopoint.com, maybe they changed something on my file there. When I tried it Rob's way it worked, so maybe it was me. The photos posted are actually real pictures that I took a digital photo of while I was holding it in my hand! They are not the clearest, but I don't have access to a scanner - yet.
Thanks for the help!!
M
Old 09-20-2000, 07:26 PM
M:
You should bite the bullet and pay the $$$ for the scanner...once you do, YOU WILL LOVE IT! I use mine daily, and would be lost without it.
Old 09-20-2000, 07:33 PM
Rob;
I probably will as I am planning a quarterly newsletter for the Yenko Deuces starting next year. I will use it then for sure!
M
