![]() Dedicated to the Promotion and Preservation of American Muscle Cars, Dealer built Supercars and COPO cars. |
Register | Album Gallery | Thread Gallery | FAQ | Community | Calendar | Become a Paid Member | Today's Posts | Search |
In regard to '70 Yenko Nova 4 speeds:
Does anybody have any ideas as to why the '70 Yenko Nova 4-speed cars were ordered by Yenko (per his order form) with M20 wide ratio Muncie transmissions, plus, all broadcast sheets found to date have an M20 code on them, and the remaining Canadian COPO Nova's 'GM of Canada' documention sheet shows code M20, yet all cars with original transmissions have an M21 close ratio trans just like Yenko's dealer brochure specified?? The only logical suggestion so far is that the COPO #9010 changed the transmission to an M21, but if this is true it would not follow the '69 COPO examples of 'engine only' changes. There is a possibility that the practice changed for 1970. The '70 Yenkos did not receive a unique engine ID code like the '68 and '69 COPO's. GM stamped the Camaro Z28 codes of CTB=4 speed, and CTC=automatics, and the Nova VIN # into the same pad. The second logical suggestion is that the trans change was part of COPO #9737. Most feel that this COPO was a carryover from '68 and '69 which did not specify any changes to the trans. There is also a possibility that this COPO # may also have changed a little for 1970. The Yenko Novas did not receive 15 inch rally wheels from '69, and didn't get a larger front sway bar only, (they received the F41 Suspensions which had a larger front bar, and a rear bar with special shocks which supposedly was only available on Super Sport cars). The Yenko Novas also received a Big Block trans crossmember, a change to COPO #9737 or part of carryover?? Any insight or thoughts are welcome!! Marlin
Marlin 70 Yenko Nova-350/360, 4speed M21, 4.10 Posi (Daddy's Ride) 69 SS Nova-396/375hp, 4speed M20, 3.55 Posi (Benjamin's Ride) 67 RS Camaro-327/250hp, 2speed Glide, & 3.08 Open (Danny's Ride) |
Marlin, According to some of the Camaro books (and CRG web site) the M20 was used as a generic term to denote a 4sp trans. on some of the paperwork. The paperwork would use the M20 code for the Saginaw 4sp and for the Muncies but the letter code on the build sheet should be for the correct trans. (I have original paperwork on a 1969 307 Camaro that has the M20 code but the car came with the cast iron Saginaw.)
I'm not sure what you mean by 69 COPO "engine only" changes. The 1969 COPO codes came with a long parts list in addition to the engine. The 9560, 9561, and 9562 COPO order listed special rear end parts, springs, radiator, hood, tires, etc. The 9737 code listed more spring options, speedometer parts, wheels, tires, etc. |
