Old 03-18-2002, 01:58 AM
Default air cleaner I.D.
Posting under this topic so i can show pics.
Old 03-18-2002, 01:59 AM
Default Re: air cleaner I.D.
Old 03-18-2002, 02:01 AM
Old 03-18-2002, 02:09 AM
Any Experts out there that can I.D. the application ?
Old 03-18-2002, 02:45 AM
CopoCrunkus CopoCrunkus is offline
67 Z-28 cowl plenum air cleaner
[Edited by CopoCrunkus (03-17-2002 at 08:45 PM).]
66 454 Chevelle
67 396 C-10 Pick up
69 427 Camaro
95 LT-1 Impala SS
Old 03-18-2002, 02:49 AM
JChlupsa JChlupsa is offline
the early Chevelles also had the same unit if i remember right
Old 03-18-2002, 03:00 AM
JoeC JoeC is offline
1987 Yugo I will give you $10.00 for it.
Old 03-18-2002, 03:14 AM
ssl78 ssl78 is offline
I think that is off a big block Chevelle. If I remember right if you look in the plenum a small block has 3 dividers where a big block would have 4 dividers. The easiest way to tell is to put it on a small block if it fits it is a small block one. A big block one will not fit on a small block without hitting the distributor. I know this because I had a cowl plenum 68 z with the cowl plenum air cleaner missing and had bought the wrong one. The other way to tell is if you have the duct a Camaro duct will have a shelf on it, the Chevelle is flat across the firewall face.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 03-18-2002, 03:36 AM
The Weird part is the Location of the Dent in the side. If you look at the dent in relation to the Plenum coming off and the centering notch for the carb. The dent points to drivers front corner. A 68 Camaro smog pump isn't over there. I am guessing it is for some type of Chevelle but would like to know the exact application.
Old 03-18-2002, 03:49 AM
jon rand jon rand is offline
66 big block Chevelle
