Go Back   The Supercar Registry > Dealer Specific Discussion > Fred Gibb Chevrolet
Old 10-15-2001, 07:55 PM
Default New Ulm, MN Harrell??
TopStock;
The only Harrell I've heard about in MN was a Cortez Silver, Blue interior, a/t on the column '69 Camaro that was from Arkansas. It ended up in Princeton,MN in the late '70's.
M
Old 10-15-2001, 08:15 PM
68TopStock 68TopStock is offline
Default Re: New Ulm, MN Harrell??
I will be going to New Ulm in the next week, and will stop by the fellow who gave me this tip. Will let you know what I find out.(shhh)
The cortex silver sounds interesting, do you know more about it?
I have recently seen a column shift '69 with blue interior, but painted black, original color was glacier blue, has Harrell emblems on the back 1/4's like Kevins. X44 code, now has a pass. '69 427/335 with T400 in it. I will post the VIN (with permission from current owner), as he is trying to determine if it is a Harrell car, transplant vs tuner. It is not a Gibb car. Car has not been touched since early '80's, does run with 75K on odometer. Apparently was from Florida in the late 70's. Stored since, however, now back on the road.
Old 10-15-2001, 09:26 PM
Here it is for all to see, the VIN and data plate information for the 1969 Camaro mentioned in the above post:
VIN: 124379N663718
Body Trim Tag:
ST69 12437 NOR351113 BDY
TR715 53 53 PNT
06A X44
Here are a couple of more clues, for you musclecar archeologists. The car is fitted with a Chevelle 12 bolt rear end, with perches and leaf springs. The passenger car 427-335hp/400T is '69 dated, is a 512 casting, but as stated above, not anywhere close as far as being original. It is out of a full size GM from what I can determine.
There is a cutout in the transmission tunnel (6x3") from a floor shifter application, but the column shifter is now operational. It has a cowl hood.
I have not inspected the car up close, to see if it has cowl hood wiring and parts, 3/8 fuel line etc. or other copo items. I hope to do this in the near future.
Old 10-17-2001, 05:17 AM
Kurt S Kurt S is offline
Back from a month in Peru.
The VIN is right in the middle of a bunch of COPO's.
And the trim tag confirms it is a Harrell COPO.
Be curious what options are on the car. Power steering, etc?
Kurt S - CRG
Old 10-17-2001, 11:17 AM
MikeA MikeA is offline
What information on the cowl tag confirms it is a Harrell COPO car?
Mike
Mike
1970 Yenko Deuce, YS-84
1972 Nova SS
1987 Grand National
Old 10-17-2001, 12:32 PM
Mike;
I believe the COPO Camaros were built in blocks of body #'s like the other COPO cars. I would imagine that there are other Harrell COPO cars that have body numbers very close to this one. If it's not the body number that signifies it as a COPO, then KurtS has another secret identity process!!
M
Old 10-17-2001, 04:22 PM
Kurt S.
Can you e-mail me your contact info., I'm sure the owner would like to review things with you.
I have another individual I have been trying to confirm things with, we know it is not a Gibb car also. The owner has been trying to identify for some time. Was a drag car since day one, original owner told him it came from Dick's shop, may have been a ZL1 transplant. Original owner has passed on now, no paperwork available yet. I'll contact him and also see if he wants to review things with you. I don't have permission to list his VIN as of now, however, am sure he would not mind posting the cowl tag.
Here is the cowl tag info:
ST69 12437 NOR 370697BDY
TR711 72 72PNT
07A X44D80
Thank you.
Ken Boje
[Edited by 68TopStock (10-17-2001 at 11:22 AM).]
Old 10-17-2001, 08:43 PM
JoeC JoeC is offline
X44 is a base car non big block unless done on some sort of special order like a COPO.
Old 11-12-2001, 06:09 AM
This past weekend I got to look up close at the Glacier Blue (now black) '69 Harrell Camaro mentioned above. It runs and drives. It does have COPO options, big block heater box, 3/8" fuel line, power disc brakes, cowl hood with firewall hole punched above main wiring box (hood had front pins/repaired on top side when repainted black). Welded plate on driver kick up area of frame rail (for dual exhaust?), 4 core staight neck radiator. Dick Harrell emblem on left front upper panel, below "Chevrolet Camaro", and on each rear quarter. No riveted Dick Harrell plates.
The body has 70+K on odometer, very nice interior, appears original, possible new carpet. No style trim, current power steering was added by last owner. The column shift for the 400 is intact and operational. There is a hole for what appears to be a auto floor shifter at one time. Welded in "bolt in" style frame connectors. Chassis has no other major mods, tubs and quarters appear original, same with entire floor, pinch welds, front clip, doors, etc., seem mostly rust free. No other options, other than a possible radio.
When I viewed the trunk, it still has a double electric race fuel pump, disconnected, but bolted where the spare would go. The lid has a spoiler, but it is not a D80 car. There appears to have at one time been an add-on spoiler on the lid. The bottom side has 5 nicely cut round holes on each side near the mid-line of the lid. Has any one seen a aero style spoiler that would mount on two perches? The top side is now patched, must have been done when repainted. Paint appears to be an older laquer respray.
It has after market wheels.
The car appears to be a former race car, reconverted to street use, with lots of originality left. The interior may have been out of the car when raced. The entire drivetrain has been replaced, with a '69 dated passenger car drivetrain, 427/335 with a turbo 400, and a '67(? hard to read cast date) CF coded Chevelle rear, with 4 leaf springs mounted with added perches. The rear may still have a 4 series posi with 4:10's. Maybe the original owner had too much into the race drivetrain and did not want to let it go cheaply, as 20+ years ago I'm sure this car sold for a bit less than todays market prices.
The current owner would like to try and locate former owner(s), car apparently has been registered in Florida, and Arkansas. Car came to Minnesota about 20 years ago, has been parked and driven occasionally since. Anyone ever hear of or see this car as a racecar, or after it was put back on the street?
Thanks for any imput.
KenB.
[Edited by 68TopStock (11-12-2001 at 01:09 AM).]
Old 11-12-2001, 12:35 PM
Ken;
Your report sounds very similar to my notes taken during a phone call to a guy named Larry in Arkansas, if you email me offline I can send you his phone number. Larry told me that he owned a '69 Harrell Camaro, 427 column shift, power disc brakes, metallic silver/blue with Harrell emblems on it. He found the car in Springdale, Arkansas, and sold it somebody in the Princeton, MN area who painted it black and changed the engine. Larry owned a used car lot at the time, and owned several hi-performance cars.
M
