Old 03-26-2026, 01:58 AM
j1m68 j1m68 is offline
Default 1967 Z28 Upper Alternator Bolt
Does anyone know what the correct 5/16" upper alternator bolt looks like? Need to know the head marking and length and the factory finish. Thanks,Jim.
Old 03-30-2026, 12:02 AM
Part # 3819910 was added in the Z28 section of the AIM with date notation of 3/8/67. The GM parts book from back then says that is a 5/16-18 x 1-1/4 bolt.
In my experience all 64-67 upper and lower alternator mount bolts were cad plated. They establish a ground, and typically cad finish was used in grounding applications rather than the more commonly used phosphate and oil.
Can't help you with the head marking for Part # 3819910.
Unless the addition of Part # 3819910 to the AIM was a late issued "correction" for a Z28 (and 3819910 was actually used the entire time on Z's), I would have to assume it was the regular production bolt before that change (dated 3/8/67) was made.
The regular production bolt is 5/16-18 x 1. Although I have seen one totally original 67 Chevelle with a longer bolt there (don't recall if it was 1-1/8 or 1-1/4).
The most common head marking I have seen on the regular production 1" long bolt on Chevelles is:
- RBW, with no hash marks, and with the letters out near the edge of the head of the bolt.
Others I have seen on unrestored 66-67 Chevelles are:
- RBW with three hash marks that meet in the center of the bolt (letters still out near the edge)
- A in the center with no hash marks
- NAT in the center with three hash marks outside of that.
The one that was longer than 1" (found on a July built Baltimore 67) was
- RSC with three hash marks, with the letters between the hash marks.
Happy hunting!
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following 2 Users Say Thank You to jeffschevelle For This Useful Post:
67since67 (03-30-2026), Hawkeye (03-30-2026)
Old 03-30-2026, 12:02 PM
Frank_Muscle Frank_Muscle is offline
Most originals were pretty typical GM hardware.
You’re usually looking at a 5/16-18 x ~1" hex bolt, plain or “TR/M” head marking, with a silver zinc/cad finish , nothing exotic
