Go Back   The Supercar Registry > Sponsors > Boulder Motorcar
Old 02-20-2026, 02:44 PM
napa68's Avatar
napa68 napa68 is offline
Default 1960 Corvette 283-290 F.I. Survivor
I put a teaser in my latest 67 L79 thread about this car. I came to know about this car last June at the 2025 Bloomington Gold show. To know me is to know how much of a sucker I am for survivor cars. This certainly fits the bill.
This car is not as pure of a survivor as some others that have passed through my hands, but still is a stand up piece. The car retains it's born with drivetrain, all original dated secondary components, a wonderful unhit body, and chassis that still retains original inspection marks and frame stencil (albeit very faint).
Delivered to VV Cooke in Lexington, KY and sold on April 2nd, 1960. It original owner Mr. Marvin Henderson maintained ownership from 1960 through 1995. At the time of sale, the car was documented to have 89,601 miles. All subsequent ownership is documented with title copies, as well as cataloging all dates, codes, and stampings in the car.
This car is well equipped with the following options......
-4 speed transmission
-Deluxe heater
-Signal seeking radio
-6.70x15 4 ply W/W tires
-Windshield washer
-Courtesy lights
-Parking brake alarm
-283 / 290hp fuel injection
-Positraction axle 4.11 ratio
-Metallic brake equipment
-Sunvisors
-Hardtop
I bought this from a friend who campaigned the car through 2025. Awards for the car include.....
-1997 Bloomington Gold Survivor Award
-2025 Blooming Gold / Gold Certification
-2025 NCRS Chapter Top Flight
-2025 MCACN Gold Concours
-2025 MCACN Triple Diamond
Not much left from a judging perspective
As one can discern, this car has been a very static piece since 1995 accumulating 994 miles in 36 years. Much of the heavy lifting had been completed by the prior owner to get the car running, driving and stopping. When I picked the car up, I knew it certainly could run better. I no sooner got it out of the trailer and went to work.
The car sounded and acted like the timing was retarded. On these F.I. cars, the distributor housing is 2pc. The lower portion is fixed, as there is an oil supply line that feeds the gear box that drives the injection unit. The top portion which contains the breaker plate and distributor cap then rotates to set ignition timing. The upper and lower portions were seized together. I was so focused on fiddling with the car, I never bothered to take some pics. Anyways, I pulled the distributor, and soaked the joint between the two with penetrant, and got that loosened up. I then loaded it up on the distributor machine to check / adjust the dwell on the both sets of points. Reinstalled, that and set the timing. Good outcome there.
Then I diagnosed the F.I. unit was not getting a vacuum signal to the power enrichment diaphragm. The unit was against the rich stop (which the oil in the engine confirmed)
The vacuum signal comes from the air meter side of the unit
Then that runs under the plenum in a steel line to the enrichment diaphragm on the fuel meter.
The stop on the right is the rich stop. It's engine vacuum that determines engine load and pulls it against the lean stop (on the left). It is those two stops that determine the "tune". This is one of the reasons big camshafts and low vacuum are a hurdle in F.I. engines.
The steel line that runs under the plenum was plugged with some kind of gunk. So I sprayed some carb cleaner in the tube, let it sit overnight, and blew it out with compressed air in the morning. I am impressed with how good the car runs.
The new plug wires should be here today, and a fresh set of tires will be here on Monday!
The Following 21 Users Say Thank You to napa68 For This Useful Post:
1967Z28 (02-21-2026), 60sStuff (02-22-2026), 67since67 (02-20-2026), 69M22Z (02-20-2026), bergy (02-21-2026), big gear head (02-23-2026), carnut4life (02-20-2026), dykstra (02-20-2026), gtomike1967 (02-24-2026), L78_Nova (02-20-2026), lakercobra (02-23-2026), olredalert (02-20-2026), PeteLeathersac (02-20-2026), Roger M (02-20-2026), RPOLS3 (02-20-2026), SS427 (02-23-2026), Tenney (02-23-2026), tom406 (02-20-2026), Washburn-Z28 (02-20-2026), Xplantdad (02-26-2026), Z282NV (02-20-2026)
Attachments - The Supercar Registry IMG_8147.jpeg IMG_7880.jpeg IMG_20260223_145827333.jpg
Old 02-20-2026, 05:15 PM
dykstra's Avatar
dykstra dykstra is offline
Lookin good Tim, I love these threads!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
The Following 4 Users Say Thank You to dykstra For This Useful Post:
69M22Z (02-20-2026), L78_Nova (02-20-2026), napa68 (02-20-2026), PeteLeathersac (02-20-2026)
Old 02-20-2026, 05:39 PM
PeteLeathersac's Avatar
Another amazing car Tim, as usual.
~ Pete
The Following 7 Users Say Thank You to PeteLeathersac For This Useful Post:
60sStuff (02-22-2026), 69M22Z (02-20-2026), dykstra (02-21-2026), napa68 (02-20-2026), olredalert (02-20-2026), RALLY (02-24-2026), Tenney (02-23-2026)
Old 02-20-2026, 06:16 PM
SupremeDeluxe SupremeDeluxe is offline
Maroon with the white cove just works SO WELL.
Eventually I need to buy a solid axle from you. It's the only generation of Corvette I haven't owned, yet. I've never even driven one.
The Following 4 Users Say Thank You to SupremeDeluxe For This Useful Post:
dykstra (02-21-2026), napa68 (02-20-2026), olredalert (02-20-2026), RPOLS3 (02-20-2026)
Old 02-20-2026, 07:41 PM
Too Many Projects's Avatar
Another VERY nice car, Tim. Somehow, I'm thinking you and your Dad will be trading Corvette's again in the foreseeable future....
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
The Following 6 Users Say Thank You to Too Many Projects For This Useful Post:
67since67 (02-20-2026), dykstra (02-21-2026), napa68 (02-20-2026), PeteLeathersac (02-20-2026), RPOLS3 (02-20-2026), SupremeDeluxe (02-20-2026)
Old 02-20-2026, 08:56 PM
napa68's Avatar
There are already some of his nose prints on the windows
The Following 11 Users Say Thank You to napa68 For This Useful Post:
1967Z28 (02-21-2026), 60sStuff (02-22-2026), 67since67 (02-20-2026), dykstra (02-21-2026), L78_Nova (02-20-2026), olredalert (02-20-2026), PeteLeathersac (02-20-2026), RALLY (02-24-2026), RPOLS3 (02-20-2026), Steve Shauger (02-21-2026), Too Many Projects (02-21-2026)
Old 02-20-2026, 10:22 PM
----To Kentuckian and southern Indianian Chevy gear heads VV Cooke was the epicenter. They sold a huge amount of Hi-Perf stuff and sponsored different racers as well....Bill S
The Following 5 Users Say Thank You to olredalert For This Useful Post:
dykstra (02-21-2026), napa68 (02-21-2026), PeteLeathersac (02-21-2026), SS427 (02-23-2026), Steve Shauger (02-21-2026)
Old 02-20-2026, 10:27 PM
Z282NV's Avatar
Z282NV Z282NV is offline
Tim, I don't know how these amazing cars find their way to you, but I'm glad they do. Are you looking for an apprentice? I am pretty handy with a broom and dust pan.
Joe
1969 Camaro
The Following 3 Users Say Thank You to Z282NV For This Useful Post:
napa68 (02-21-2026), olredalert (02-21-2026), Steve Shauger (02-21-2026)
Old 02-21-2026, 01:21 AM
Steve Shauger's Avatar
Administrator
What a feeling you must get from diagnosing and solving the problems. Well done Tim!
www.vintagecertification.com
The Following 6 Users Say Thank You to Steve Shauger For This Useful Post:
60sStuff (02-22-2026), dykstra (02-23-2026), napa68 (02-21-2026), olredalert (02-21-2026), RALLY (02-24-2026), Z282NV (02-21-2026)
Old 02-22-2026, 09:41 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Tim,
I’m sure you will post a legible photo of this triangle tag as I’m curious of the information.
PS, and the Oil Change sticker ….. when you have a moment …..no rush.
PS, this FI is so cool !!!
The Following 4 Users Say Thank You to 60sStuff For This Useful Post:
napa68 (02-24-2026), olredalert (02-22-2026), RALLY (02-24-2026), Z282NV (02-26-2026)
