Old 02-17-2026, 02:49 AM
NorCam's Avatar
NorCam NorCam is offline
Default NOS 454 LS7 #3965774 w/ GM Ink Stamps & Paint Marks
Bought this LS7 motor yesterday and thought to share some pics of the paint marks and ink stamps on the NOS block. It's GM part #3965774 which is the over the counter long block 454 LS7 motor. This one was squirreled away in a private collection of engines and parts and I was excited to score this one.
Haven't decided exactly what I'll do with it just yet but leaning towards another Day 2 build with this serving as the foundation. Maybe clear coat the block and heads to preserve the ink stamps and markings. It came with the NOS 990 heads, tin work, flywheel and balancer, and the seller threw in a Tarantula TM-2R intake and 4296 Holley #3955205 Carburetor to go along with it.
It should make some decent power.
The Following 15 Users Say Thank You to NorCam For This Useful Post:
67SS4spd (02-21-2026), 69Z11Pacer396 (02-17-2026), Arrowsmith (02-17-2026), big gear head (02-17-2026), Damien (02-19-2026), dykstra (02-17-2026), enio45 (02-17-2026), jerry455 (02-20-2026), L78_Nova (02-17-2026), lbnaz (02-17-2026), olredalert (02-17-2026), PeteLeathersac (02-23-2026), SS427 (02-17-2026), SuperNovaSS (02-17-2026), Tenney (02-17-2026)
Old 02-17-2026, 03:00 AM
luzl78 luzl78 is online now
Love those piston domes!
Old 02-17-2026, 03:04 AM
scuncio's Avatar
scuncio scuncio is offline
Nice short block. You planning to run those pistons as-is? I’ve thought hard about doing a high compression purpose built 427 but know it would be tethered to c16 or similar race fuel.
Old 02-17-2026, 03:14 AM
NorCam's Avatar
Could mill down the pistons but that means rebalancing the assembly after it was just taken down, clearanced and reassembled.
Those domes make 12.25:1 compression with the 990 heads so I'm going to explore thicker head gaskets to see what compression can be bled off. Maybe that and keeping the timing a few points lower with some race fuel mixed in will fit the bill. I am also at 3600' elevation so that does allow for a decent compression write off as I understand it. This would be run strictly as a Saturday night special when I want to go out and rip a few gears around town.
Old 02-17-2026, 03:35 AM
dustinm dustinm is offline
Bleeding off compression with headgaskets will not produce the results you are seeking. It will overheat, be down greatly on power vs an engine built with the correct "quench" at the same lower compression. I think i would just make buddies with the local airport manager to source a steady supply of avgas. I mean how much do you plan to drive it anyway? I average less than a thousand a year with a more streetable engine and with a rowdy engine like that, even lowering the compression to a reasonable number, it would be even less.
It sure is a super cool find !!! Even if you put it under a glass table to stare at it would still be cool
The Following 4 Users Say Thank You to dustinm For This Useful Post:
Arrowsmith (02-17-2026), Chuck_Burg (02-21-2026), Lynn (02-17-2026), NorCam (02-18-2026)
Old 02-17-2026, 04:17 AM
ZAPPER68 ZAPPER68 is offline
Interesting...today I installed the crank and pistons in my LS7 after a refresh. I'll have it assembled by the end of the week and it's going back in my '69 Camaro.
My Camaro is a 45K mile original, Fathom Green, medium green interior, powerglide, 10" convertor with 5.13's. Perfect for going for an icecream this summer...
The Following 5 Users Say Thank You to ZAPPER68 For This Useful Post:
69M22Z (02-17-2026), dustinm (02-20-2026), olredalert (02-17-2026), PeteLeathersac (02-23-2026), Xplantdad (02-24-2026)
Old 02-17-2026, 10:34 AM
dykstra's Avatar
dykstra dykstra is online now
Way cool!!! Congrats on a killer score!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
NorCam (02-18-2026)
Old 02-17-2026, 01:55 PM
Agree 100% with dustinm.
Old 02-17-2026, 02:13 PM
Its interesting that the head surfaces are milled instead of broached like the oil pan and mains are. GM must have preferred a secondary cleanup cut on this engine. I wonder if it is machined to a zero deck height?
Owned since 1978 - First Car
Old 02-17-2026, 02:52 PM
L_e_e's Avatar
L_e_e L_e_e is offline
Great piece, I would 100% plan on disassembling and going through it, I've seen plenty of those LS-7 (XCH) crate motors that were poorly machined and assembled.
The Following 7 Users Say Thank You to L_e_e For This Useful Post:
66cayne (02-17-2026), 67since67 (02-21-2026), Arrowsmith (02-17-2026), cheveslakr (02-17-2026), Denis Guenzel (02-17-2026), NorCam (02-18-2026), olredalert (02-17-2026)
