Old 02-05-2026, 06:46 PM
302moz 302moz is offline
Default 67-69 Camaro 23 inch radiator brackets
Wanted a pair or singles 23 inch 4 core or 3 core radiator mounting brackets . They are the same . Thanks call/text 9063371025
Old 02-05-2026, 07:11 PM
Default Heartbeat Repops
I just seen Heartbeat is selling the correct repop ones . Has anyone used them ?
Old 02-06-2026, 03:02 AM
enio45 enio45 is offline
3 core and 4 core brackets are different......4 core is wider so a wider bracket......i just received a 4 core rad core with brackets from HBC - they are wide to cover all the cores.
i may have a set of 3 core orig brackets....let me know if that is of interest and ill ck.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-06-2026, 03:33 AM
Default 3 vs 4 core
The right tank OO is used on 4 core and three core .They take the same brackets .Double check your information source.
Old 02-06-2026, 03:34 AM
Default Brackets
Yes interested in the brackets . Thanks
Old 02-06-2026, 04:45 AM
are u talking about the upper and lower brackets that are 23 inches long.......?
Or are you talking about the side tanks on the left and the right.....
or are you talking about the mounting brackets that attached to the side tanks
this would help to understand which ur talking about....then i can see what i have to help you.
u mention 23 inch - so i assume ur talking about the top and bottom core brackets??
if so they are different for 3 core rad and 4 core rad.
which items are u talking about pls
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-06-2026, 09:08 AM
Default 23 inch radiator brackets
I was very clear the side brackets that are soldered on the tanks .They hold the radiator to the radiator support.Those are the parts I need .Guaranteed the same for a three or four core .You have them mixed up with the top and bottom channels that are soldered to the core .The channels are different between a three core and a four core .The width is different.Heartbeat sells a beautiful repop of those and I have been using them for years .Thanks
Old 02-06-2026, 02:30 PM
Thanks for the clarity - yes i agree the mtg brackets to the tanks are the same - the top and bottom rails are not - i just restored a 3 core rad and a 4 core rad.
I have an extra set of top and bottom 23 inch rails.
Never used the HBC side tank brackets, they look right on from the pics - probably your best avenue - i looked around for side brackets recently and not much out there - 427 King has a set, thats all i found. I repaired mine. GLW the search. Let us know how the HBC ones work out IF u get them.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-06-2026, 02:41 PM
plumL78 plumL78 is offline
Eddy i think the confusion here it he is talking about a 69 big block rad. they were 3 and 4 core with the same brackets. oo is a 69 big block right side tank
Old 02-06-2026, 02:59 PM
No problem- just trying to be clear which parts are needed that I can help with.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
The Following User Says Thank You to enio45 For This Useful Post:
hiperf69 (02-09-2026)
