Old 02-01-2026, 03:11 PM
ALLZS ALLZS is offline
Default Inner fender dust shields
what is everyone using for the staples to secure the flaps to the inner fender the ones they give you in the kits are very hard to work with there has to be a better way
Attachments - The Supercar Registry Splash Shield Staples.jpg PXL_20260202_175141223.MP.jpg Inner fender splash shield staples.jpg A arm Dust Shields 4.jpg
Old 02-01-2026, 04:00 PM
Tinkerman Tinkerman is offline
Default Inner Fender Staples
I used the supplied staples. But punching them through the inner fender sheet metal was a challenge. What I ended up doing was drilling staple sized holes with a small drill bit using a pre-sized wood block template. I then pressed the staples through the fender and dust shield and then pressed the staples legs together. It took time and was a PITA but it came out looking okay for my restoration.
Old 02-01-2026, 04:05 PM
enio45 enio45 is online now
or buy some stainless/steel wire and make your own -
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-01-2026, 04:37 PM
169indy's Avatar
169indy 169indy is offline
I Used the "Lloyd-Chick" Trick.
Medium sized staples, straightened out and cut to length re bend insert and fold over.
It is a bit difficult to do a one person install, you also need to pierce the rubber and use a small pair of round nose pliers to "Roll" the ends to simulate a mechanical-stapler crimp.
With practice and time it can be done in a manner to replicate a factory installation vice the repop square body roofing staples supplied.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 3 Users Say Thank You to 169indy For This Useful Post:
dykstra (02-02-2026), mhm1966 (02-02-2026), olredalert (02-01-2026)
Old 02-02-2026, 01:45 PM
what size stainless / steel wire will work the best
Old 02-02-2026, 01:57 PM
I believe lloyd used 17 gauge zinc plated wire from a spool. 17 gauge is about .054 thick. Looks to be size in the pic as the large paper clip.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-02-2026, 05:58 PM
mhm1966 mhm1966 is offline
That is correct about what Eddie said. This is what Lloyd used, 19 gauge galvanized very easy to work with.
1966 Corvette Coupe L79 Mossport Green
1969 Camaro Z/28 Hugger Orange
NCRS #22211
Old 02-02-2026, 08:14 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
I used a coil wire that farmers use to build electric fences for cattle. A guy told me about it. It won’t rust and has a medium stiffness to it. Worked fine.
Richard
1967 Camaro SS 396/375 4K
Old 02-02-2026, 08:28 PM
I use aluminum wire peened over the jaws of my linesman pliers. A 1/16" drill to enlarge the factory holes a bit and the same pliers to bend both ends towards each other, then a body hammer to lay them flat. Won't corrode, simple to bend, and they have lasted over 20 years on at least 2 cars.
