Old 01-26-2026, 10:45 PM
ALLZS ALLZS is offline
Default Front lower shock bolt
anyone happen to have a picture of the correct style bolts used to atatch the lower front shock on a 69 camaro
Old 01-27-2026, 01:22 PM
KevinW KevinW is offline
Here are mine, which I think are correct: #9420555 7/8" long, RBW flange head with a dimple.
69 327 convertible (driver)
The Following User Says Thank You to KevinW For This Useful Post:
mhm1966 (01-27-2026)
Old 01-27-2026, 02:47 PM
thats what i have but in the legends book they call for a floting washer so whats correct ?
Old 01-27-2026, 02:58 PM
I don't see any "washer" in the AIM, just the bolt and the nut/clip.
Old 01-27-2026, 03:40 PM
X66 714's Avatar
X66 714 X66 714 is offline
Mine doesn't have floating washers either. What does BBBenny say about those bolts?....Joe
Old 01-27-2026, 04:56 PM
mhm1966 mhm1966 is online now
I agree with Kevin's picture of what the bolts and clips should look like, but I know a Legends Judge that looks for the floating washer on the bolt.
1966 Corvette Coupe L79 Mossport Green
1969 Camaro Z/28 Hugger Orange
NCRS #22211
Old 01-27-2026, 05:54 PM
Diamond_Don Diamond_Don is offline
It's possible the bolt may have to be longer than 7/8 inch when the washer is used in this application... ???
Old 01-27-2026, 09:18 PM
What part number is in the AIM? And does it say "SCREW" or "SCREW ASM" ?
When a separate washer was attached to a bolt (not removable) it is typically described in the AIM as a "SCREW ASM" - for "assembly" denoting that the part consists of more than one component.
As to length, I could be wrong, but I believe when a washer was attached to a bolt the nominal measurement of bolt length was taken from the base of the washer to the end of the bolt, not from the base of the bolt head to the end of the bolt.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 01-27-2026, 09:59 PM
69 Camaro AIM UPC 3 page A4 says: 5 - 9420555 SCREW
So no "floating" washer then
Old 01-27-2026, 11:05 PM
Seems like I have seen this both ways on original cars. Charley just acquired a 9300 mile time capsule, early LOS built Z. Would be interested to see a pic of them. Just went downstairs and checked my car, which I have owned for 51 years. They have captured washers on all four. I am 99% certain that is what I took off; but there is no way to know whether a PO swapped them when putting shocks on it early on.
