Old 01-02-2026, 01:59 AM
jwcarguy jwcarguy is offline
Default 1970 Camaro Z28 Brake Distribution Switch Block/Hold Off Valve/ Metering Valve/ Lines
I have a rare only year only setup, from all research, for a 1970 Camaro Z/28 (not sure on the SS ?) Brake Distribution Switch Block, with Hold Off Valve (proportioning), Metering Valve, Mounting Brackets, Bolts, Original Steel Lines
hard to find all assembled with these 3 main components together, plus lines and brackets
-Distribution Block date stamp 0 079 (March 20, 1970)
w/ switch
Weatherhead bracket Patent #'s 3369090 3374322 w/ Bolt head " S "
- Hold Off Valve (Kelsey Hayes) date stamped 019 0 (Jan 19, 1970)
-Metering Valve #2226261 (hard to read in casting) date stamped 063 (March 4, 1970)
has rear rubber cap #2225847
mounting bracket with bolt and star washer
- (5) lines include:
(2) to master cylinder from dist block and metering valve
(1) dist block to metering valve
(2) holdoff valve to dist block
other pics on request
$270 shipped in US (others , please contact me)
pm/ call/ text (702)677-4085
in Las Vegas, NV
Attachments - The Supercar Registry thumbnail_IMG_8857.jpg thumbnail_IMG_8856.jpg thumbnail_IMG_8855.jpg thumbnail_IMG_8853.jpg
