Old 12-28-2025, 10:20 PM
jwcarguy jwcarguy is offline
Default late 69 Camaro Z28 SS396 12 Bolt Rearend BU 3.73 posi
I have a nice late production 1969 Camaro Z/28 or SS396 12 Bolt rear axle assembly, just removed from a car that has been off road since 1988
stamped code is " BU " ( possibly a "C BU" that they used late production, has tiny dings where C would be)
housing casting #3969341NF , the casting date can't be made out
assembly date is 10/15 (Oct 15 1969)
Eaton Positraction original 3 series carrier #30140PM1
original 3.73 ratio GM gears dated 8/ 69 (Aug 69)
has original pinion yoke w/ u-joint retaining straps, original correct rear axle fill plug w/ Positraction Diff lube only plate
correct brake hose to housing bracket,
original cover
U-bolts and T- bolts w/ nuts
has drum brakes with original e-brake cables
(2) new correct lower 12 bolt multi-leaf shock plates and shock studs
this is a hard to find rear with all correct original parts for the person restoring a late production car correctly
no wheels/ tires are included
$3200
pm/call/ text (702)677-4085
in Las Vegas, NV
any shipping is buyers responsibility to arrange and pay for, willing to pallet/ crate and deliver to freight terminal for additional cost
Attachments - The Supercar Registry thumbnail_IMG_8727.jpg thumbnail_IMG_8726.jpg thumbnail_IMG_8725.jpg thumbnail_IMG_8722.jpg
Old 12-29-2025, 12:17 AM
enio45 enio45 is offline
nice orig rear!!! GLWS
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
The Following User Says Thank You to enio45 For This Useful Post:
jwcarguy (12-29-2025)
Old 12-29-2025, 02:25 AM
Being a late rear, it likely had a "C" in front of the "BU" code. You can see where it was obliterated with a punch. Pretty common to see them both ways.
Nice piece for someone with a late Z.
Old 01-18-2026, 02:44 AM
Can work with buyer on shipping
Tags
z28 ss396 12 bolt
