Old 12-14-2025, 12:41 AM
Vortecpro Vortecpro is offline
Default 1966 L72 427 IP Code
1966 L72 427 IP code, L/65 date code, 942 casting, matching 858 heads. Block, crank, rods, heads. The block is STD bore with one sleeve that appears to be done right, no damage to the bottom of the bore. There is O (ZERO) rust issues in the bores, pictures show where I took sand paper to the worst cylinders, again no pits whatsoever. The heads from what I can see have not been destroyed by butchers, I see no bolt problems. Pretty clean core. 4500.00 719 650-1609 There is a VIN number.
Attachments - The Supercar Registry IMG_0328.jpg IMG_0327.jpg IMG_0326.jpg IMG_0325.jpg
