Old 11-23-2025, 03:51 PM
Smile Brand New MSD Ultra 6AL
Brand new, in the box MSD Ultra 6AL. Part number 64233. $289
This is a compact (it's Tiny!) digital multi-spark box with considerable improvements and features over earlier examples:
Features:
* High conversion efficiency ensures minimal heat generation and maximum spark energy output with less current draw from the battery
* High RPM operation and maximum output using the Blaster HVC, PN 8252 or HVC II, PN 8253 * Powerful capacitive discharge of multiple sparks improves performance
* Consistently high spark energy of 135mJ to 150mJ for every firing, from idle to redline RPM
* Increase spark series duration lasts for 18 of crankshaft rotation
* Easily installs on 4, 6, 8-cylinder engines with distributors
* Operates on most 7 to 28 volt electrical systems
* Connects to points, magnetic pickups, and hall/crank input distributors
* Bluetooth connectivity to mobile app interface for settings and monitors
* MSD CAN communication for easy connectivity to MSDView using a CAN MSD Hub and Power Grid USB or CAN-USB Bridge 89982 product
* Fully protected against an open coil, shorted coil and open load
* Compact design full MSD power
* Quickens throttle response and improves starting
* Tach Output
* Launch, Burnout, and Step Retard activation inputs available. This ignition box has a built-in tri step RPM rev limit controlled by the mobile app
* Mobile app available settings: Cylinder selection, Step retard value, Launch RPM value, Burnout RPM value, Max (Race) RPM Value, Start retard value
* Programmable Step Retard: On Ramp time, Off Delay, Off Ramp Time, Engine RPM for activation
* Programmable Start Retard: 0, 10, 20 degrees
* Alerts and monitors available
* High level of security connection from phone to ignition box (encryption), including sequence in push-button implementation
* Maximum programmable retard of 30 degrees
Reason for selling? I just don’t need all of the features. Box was opened and the MSD was removed to take photos. Brand new. I can easily ship by way of the post office.
Thanks! W
