Old 11-23-2025, 03:37 PM
Smile Miscellaneous C3 Corvette Parts
Corvette Parts For Sale
The following parts were removed from my 1971 NCRS Top Flight Restored Corvette (small block 350-270 manual transmission, standard suspension application without AC car). All parts are in mint or new or as new condition, unless noted. I can supply photos upon request. Prices are OBO and in US $$$. Parts are located in Delisle, SK., Canada (north of Montana). For most parts, I can ship by way of the post office.
• 1971 small block upper and lower rad hoses - $50
• 2-inch Exhaust Center Hanger Bracket - $25
• 1971 Small Block Lower Alternator Bracket - $75
• 1971 Small Block Fan Belts (3935420 & 3847704) - $50
• 1971 Small Block (350-270 with Aluminum Rad) Fan Shroud - $230
• Small Block Water Pump 3991399 - $269
• 1971 Small Block Radiator Support (non-AC w/ aluminum rad) - OEM and Mint! - $300
• 1971 Delco Starter 1108338 - $225
• 1970-71 Non F41 Delco Pliacell Shock Absorbers. Front 3192196 with 253-70 Date Code. Rear 3192869 with 227-70 Date Code - $799 OBO
• 1971 small block dipstick & tube (production line part with taper) - $90
• C3 2.5-inch half shaft set (missing one u-joint and two sets of caps) - $90
• Stock spring bolt set & OEM bushings (used) - $25
• C3 ¾-inch front sway bar with bushings & end links - $125
• 1969 & up park brake console, no PW, new black reproduction - $90
• C3 2.0-inch exhaust system, complete (mint) with correct tips - $545
• 1971 CEC/TCS complete system - $250
• 1968-74 front springs, non F41 small block - $105
• 1971 Low HP tach and speedo faces - $61
• 1971-80 3991423 BW water pump pulley - $100
• 1971 Packard Wire Set reproduction (3Q70 date) – $75
• AC Acniter II spark plugs NOS R44TS - $192
• AC 329C Air Filter Element. Original Equipment GM production line with correct welded mesh. $199
• New repro stainless door (window) moldings (left and right) - $85
• Rear “CORVETTE” emblems (used – some stud threads need repair) - $25
• New M&H Electrical Transistor Ignition (K66) wire harness - $179
• Console park brake seal (slider) - $3
• Evaporative Emission cannister; restored with mount bracket - $89
• Astro vent air duct (accordion tube) passenger side - $5
• 5 correct restored small block bellhousing & rear lift bracket bolts “M” head marking - $15
• 12 correct restored small block exhaust manifold bolts “O” head marking. Includes 8 heavy washers and 4 French locks - $25
• 2 correct restored small block fuel pump bolts & washers “anchor” marking - $10
• 2 correct restored Rochester Quadrajet mount bolts “P” marking - $5
• 6 correct restored flywheel bolts “O” Grade 8 marking & 6 restored pressure plate bolts ‘A” head marking- $24
• 4 correct restored small block water pump mount bolts. 2 with “RSC” marking; 1 with “C” marking; 1 with clutch head marking - $10
The Following User Says Thank You to Arrowsmith For This Useful Post:
olredalert (11-30-2025)
Tags
c3 vette, corvette parts
