Old 11-05-2025, 05:12 AM
Motorhead848 Motorhead848 is offline
Default 1969 Camaro vinyl top trim
I’m in the process of restoring a 69 Camaro with a vinyl top. The original trim has been polished and I need to repaint the black paint in the center. Every time I paint it and peel the masking tape off, it takes some paint with it. Does anyone have a method or type of paint that left a clean straight line and doesn’t take the paint off when peeling the tape off??
Thanks mark
Old 11-05-2025, 03:13 PM
pdphilson pdphilson is offline
you could try pin strip tape -- or black finger nail polish -- or dont tape and go over with soft cloth and laquer thinner after painting which would probably be the best
The Following User Says Thank You to pdphilson For This Useful Post:
Z282NV (11-05-2025)
Old 11-05-2025, 04:09 PM
Kurt S Kurt S is offline
I bet part of the issue is that it was polished. Originally, it was plated.
Kurt S - CRG
Old 11-05-2025, 04:18 PM
Z282NV's Avatar
Z282NV Z282NV is offline
^^^ THIS^^^^ is a great idea.
Joe
1969 Camaro
Old 11-05-2025, 04:25 PM
169indy's Avatar
169indy 169indy is offline
I think you need to establish some "tooth' to the painted surface.
Suggestion #1 Mask and use a narrow Dremel 3m scotchbrite wheel and abrade the exposed painted surface. Remask and refinish.
Suggestion #2 Could be the angle you re "pulling" on the masking, It need to be pulled at 180 degrees, dont pull "UP" lifting paint.
Suggestion #3 Timing, more cure time required before masking removal.
Hope this is helpful
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 11-05-2025, 04:51 PM
Derek69SS Derek69SS is offline
Or less time. Pull the tape while the paint is still wet so it doesn't stick to the tape.
The Following User Says Thank You to Derek69SS For This Useful Post:
L78_Nova (11-05-2025)
Old 11-05-2025, 10:15 PM
thehornworks thehornworks is offline
Just did mine. Use blue pin stripe tape. 2 med.thin coats and walk away. Etch primer first
The Following User Says Thank You to thehornworks For This Useful Post:
dykstra (11-14-2025)
Old 11-06-2025, 05:04 AM
Thanks everyone for the ideas and tips. I’ll give them a shot and see what we get!
Old 11-07-2025, 01:14 PM
I've had good results by spraying black and then using a sponge with lacquer thinner to wipe off the high surfaces
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
dykstra (11-14-2025), Xplantdad (11-07-2025)
