Old 10-26-2025, 12:44 PM
Tidmack Tidmack is offline
Default 2020 ATC Quest 2 Car Stacker Trailer 19,800 lbs GVWR Custom Paint Race Hauler
Located in Elroy, WI 53929. Dimensional specs listed below.
2020 ATC Quest stacker trailer measuring 31' overall (interior box length is 26'). This beautiful ATC car hauler has limited miles, is in FANTASTIC condition in and out. It's always stored under a carport, so the paint and trim retains high gloss. No maintenance is needed at this time, and the trailer is ready for continued use.
Video and additional photos here: https://www.ebay.com/itm/197737528987
Known for their superior quality, ATC makes incredibly strong, durable trailers, while keeping unit weight as low as possible. Dry, this trailer weighs around 7,500 lbs., and is rated to carry an additional 12,400 lbs. of vehicles and cargo. Quality tires are mounted on the matching aluminum wheels attached to the 6,000 lb. tri-axles. Made in Nappanee, Indiana, ATC has a reputation for over-building their trailers, and this custom stacker is no exception.
Exiting and accessing vehicles is made EASY with the incredibly large hatch on the driver's side of the hauler. An oversized door near the front of the passenger side allows for quick entry to the attic, front of the vehicle, or any cargo stored in the front compartments.
With an interior height of just over 11' and 26' of box length, folks have tons of flexibility with the ability to haul two full size cars, or even a car and SUV if the combined heights work out. Motorcycles and golf carts can also be mixed in with ease! With total cargo capacity of over 12,400 lbs. and 6,000 lbs. on the raised lift, endless combinations will work while traveling with additional vehicles. Note that the floor-mounted D-rings allow for quick, safe connections, and ample lighting serves as a welcomed guide when strapping down in the dark.
This is a top of the line trailer that now retails for over $90,000 new.
Helpful Numbers and Dimensions (dimensions also in interior video below)
GVWR: 19,800 lbs.
Cargo Capacity: 12,400 lbs.
Interior Height: 11' 4"
Allowable Length of Vehicle on Bottom Level: 22' 2"
Lift Platform Length: 14'
Lift Platform Width 79"
Drivable Width Between Fenders: 80.5"
Overall Width: 97"
Counters in front are 24" deep, with portion on the "L" an additional 21"
Floor Space in Front of Counters in Front of Lift is Approximately 63"
Attachments - The Supercar Registry IMG_20250917_093352[1].jpg IMG_20250917_093311[1].jpg IMG_20250917_093305[1].jpg 20250916_132235.jpg
